Matter Timeline
The Matter Timeline makes it quick and easy to see all activities or actions that have happened on a particular matter. This feature helps keep every staff member on the same page in regards to what has happened in every matter.
Use the Matter Timeline to immediately understand the history and progress of your matters.
Matter Timeline Basics
Every Matter has a Timeline. Select Timeline on Widgets to switch to the Timeline View.
The Timeline shows every email, Communicate Messages, Memos, Tasks, Events, etc. completed for the Matter.
  • The Timeline is organized showing the newest activities completed. Scroll down to see additional activities.
  • Select any of the arrows to minimize or expand the level of detail provided on each activity.
Select any of the activities to open and review the activity in further detail.
To set Matter Timeline as your default view over widgets, right-click and select Set as default.
Smokeball has additional features to help you stay on top of every detail of your matters.
  • Activity automatically tracks how much time is spent on all activities in Smokeball. Use Activity to make billing easier and understand your profitability. Learn more about Activity .
  • Matter File History can be used to see all changes made on any file. Learn more about Matter File History.
1 out of 3 found this helpful
