Set up Personal Injury Matter Tags
Create default matter-specific tags to further categorize your personal injury matters. Your tags will appear across the top of the Matter window and in the Tags column on the Smokeball Matters tab.
Personal injury firms use matter tags in a variety of ways. You can apply an unlimited amount of matter tags to organize your matters or run custom reports.
Personal Injury Matter Tag Examples
Personal Injury – Plaintiff:
  • Slip and Fall
  • Medical Malpractice
  • Nursing Home Abuse/Neglect
  • Animal Attack
  • Wrongful Death
  • Gross Negligence
Motor Vehicle Accident – Plaintiff:
  • Wrongful Death
  • Motorcycle
  • Truck
  • Bus
  • Construction Vehicle
  • UM/UIM
If you are unsure what tags could be useful to your firm, reach out to your Account Manager for additional help.
Once you assign a tag to a matter, it will appear at the top of the matter.
How to Assign or Edit Matter Tags:
  1. Within your open matter, click the + at the top right of the screen.
  3. Click outside the tag box to close it.
To add an additional tag within your open matter, select Edit Tags and add additional default options. blobid1.png
Did You Know?
  • You can filter your matters on the home screen by matter tags using the filter.
  • You can add a widget to your dashboard to see tagged matters in groups.
2 out of 2 found this helpful
