Viewing messages and managing conversation participants
Learn how to find all Internal and External messages addressed to you and how to access them at any time.
View messages in the Smokeball Desktop App
Plan_GrowProsper.svg
When you receive a new message, a notification will display on the firm-level Messages tab. It also contains conversations across all matters.
If you’re in a matter that has a new message, the notification will also display in the Messages tab of the matter:
You’ll also receive a notification on your Windows taskbar:
If you don't have the Smokeball window active, Smokeball will also send a Windows desktop notification for any new messages that remain unread after 30 seconds. Note that this only works if any Windows notification blockers, such as Focus Assist, are turned off.
View messages in the Smokeball Web App
Plan_BoostGrowProsper.svg
The Client Portal can be accessed by selecting Messages from the left panel. When you receive a new message, a notification will display there.
01H80Y0232C3CKGX46ANPXNZ6B
How to tell if a participant has viewed a message
An icon will appear next a message when a conversation participant has viewed that message. Hover over the icon to view timestamps and all other participants who have seen the message.
Search for a message or file in a conversation
Use the Search bar at the top of the Messages tab to search all of either Internal or External conversations you have access to. We recommend entering at least one word for best results.
Hover over the search bar and click on the X to exit search and go back to your messages.
Add participants to a conversation
To add users to a conversation, select the Info icon on the top-right corner of the channel.
If the conversation is an Internal Matter Conversation, select the staff members to add from the drop-down menu, then select Add.
If the conversation is an External Matter Conversation, you can add both Internal Participants (Staff) or External Participants. Select Add from matter contacts if the person's details are already in a Smokeball contact card, or select Invite guest by email and enter their email to send them a Client Portal invitation.
Remove participants in a conversation
To remove users after a conversation has been created, select the Info icon on the top-right corner of the channel.
Hover over a participant's name, then select Remove. You can also remove yourself by clicking Leave Conversation.
1 out of 3 found this helpful
