Sending direct messages to staff using Smokeball
Smokeball's Messages feature serves as both an external communication platform and an internal communication hub.
In addition to easily sending messages and sharing files with individual users or groups within your firm, you can create channels to keep everyone up-to-date and on the same page.
Starting direct message or group conversation
To start a message to staff member/s:
  1. Select Messages from the main Smokeball window.
  2. Select the Plus icon in the Direct Messages section.
  3. Select one or more staff members from the drop-down menu.
  4. Enter your first message in the text box at the bottom of the screen, then hit Enter on your keyboard or click on the Paper plane icon to send the message.
Like in a conversation with your client, you can view files shared and pinned messages from the Files and Pinned tabs.
Internal Direct Messages can also be viewed from the Communicate Mobile App.
Loop in staff members on a matter
If you would like to send a staff member a message about a specific matter, you can create an Internal Matter Conversation. This ensures all correspondence and activity related to a particular matter stays within Smokeball.
  1. Open a matter and select the Messages tab.
  2. Select the plus icon under Internal Matter Conversations.
The internal conversation will be accessible from the left-hand panel of the matter file at any time. They can also be accessed from the Communicate Mobile App.
2 out of 10 found this helpful
