File Republic Storage Integration
Learn how to connect File Republic Storage (formerly known as FileMan) to Smokeball, allowing you to access Smokeball matters in File Republic Storage.
This article relates to the File Republic Storage App and its integration with Smokeball. Refer to the File Republic Productivity Integration article if you're looking for an integration with the File Republic Productivity App (formerly known as BundlePro).
What is the File Republic Storage Integration?
File Republic Is a cloud-based information management platform that allows your firm to manage the storage or destruction of closed files as a one-off disbursement. Learn more about File Republic on their website.
Already using File Republic Storage?
Before you enable the integration in Smokeball, call File Republic on 1800 820 061. File Republic will configure your account to ensure your files sync across to Smokeball properly.
By integrating with Smokeball, you can gain access to the File Republic portal directly from a matter, where you can access archived files or request retrieval.
Enable the File Republic Storage Integration
  1. Select the Gear Icon on the top-right corner of Smokeball to access Smokeball Settings.
  2. Select Integrations from the left menu, then select FileMan
  3. Click Authorise to get started.
  4. Enter your File Republic username and password to connect the integration. You will be presented with a confirmation message once this is completed.
  5. The integration can mark a matter as Closed when File Republic receives and scans the first physical pages of the files in a matter. If you would like to enable this, tick the box.
How the File Republic Storage Integration works
When you open a new matter in Smokeball, its data is sent to File Republic. File Republic creates a record and a one-off disbursement on the Smokeball matter. Note that this disbursement is only recorded when a Person Responsible is assigned to the matter.
Disbursements are created for every Smokeball matter. Contact File Republic directly if you wish to reverse a disbursement for a specific matter.
When a matter is ready to be archived, File Republic will come to your office and collect the physical files related to the matter. These are then scanned and uploaded to the File Republic portal, where you can access the files, request retrieval and more.
To access the File Republic portal:
  1. Open the matter, then double-click on the Info field to access Matter Info.
  2. Select Go to FileMan in the bottom-left corner.
Note: This link will only work after matters are synced to File Republic, which currently happens overnight.
