Use Smokeball along with PaperCut MF to streamline your workflow.
PaperCut MF is a print management platform for printers and multifunction devices (MFD). With the PaperCut MF integration, you can:
- Scan documents directly from your MFD directly to client matters in Smokeball.
- Print against an activity code and recover associated costs with ease.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Dynamic Connect (https://dynamicconnect.com/).
How to obtain a PaperCut MF account
PaperCut MF is not sold directly to consumers - it is sold through a group of authorised partners. If you are interested in PaperCut MF simply contact your printer servicer, the company that supplies you with your copiers and MFDs. Learn more on PaperCut's website.Â
Connecting PaperCut MF with Cilantro
Cilantro by Taco Technologies is an authorised distributor of PaperCut MF that facilitates the connection between Smokeball and PaperCut MF. Learn more about Cilantro below:
To get started with Cilantro, get in touch with the Taco Technologies team on their website.
How the PaperCut MF Integration works
The integration will all be configured by your authorised print reseller. There is no need for you to configure any settings in Smokeball.
Open/Pending matters are synced to PaperCut MF from Smokeball every hour.
Scanning documents to Smokeball
To scan a document into Smokeball, select Scan on your MFD, choose the relevant matter and select Scan to Smokeball.
Printing documents from Smokeball
To print documents against a Smokeball matter, select Print on a document, then simply select the relevant matter in the PaperCut MF pop-up. Smokeball activity codes are synced to PaperCut MF so that all disbursements are recorded correctly.
