Learn how to integrate Smokeball with AI Legal Assistant, an Australian-based AI software for lawyers.
Learn more about AI Legal Assistant on their website, where you can also book a demo with the team.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to AI Legal Assistant (https://legalassistant.au/).
Connect Smokeball to AI Legal Assistant
To get started:
- Open AI Legal Assistant.
- Select your profile picture on the top-right corner, then select Integrations.
- Select Connect under Smokeball.
- Log in with your Smokeball username and password.
- Navigate back to the home page in AI Legal Assistant. A Smokeball folder will now appear under the Integrations section.
Working with the AI Legal Assistant integration
Whenever you create a new document in AI Legal Assistant, a version of this document will be saved to the Smokeball matter.
AI Legal Assistant utilises the power of AI to cut down time spent working on tasks such as document review, research and chronologies. For more information on how to use AI Legal Assistant, refer to the Smokeball integration page on the AI Legal Assistant website.
