Birdeye Integration
Plan_BillBoostGrowProsper.svg
Connect Smokeball client data to Birdeye to efficiently manage review requests seamlessly.
Birdeye is an all-in-one platform that helps your firm manage client interactions. Use Birdeye to manage your firm's digital footprint, such as requesting reviews from your clients, boosting your firm's visibility on search engines and converting website visitors into leads.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Birdeye (https://birdeye.com/au/).
How the Birdeye integration works
The Birdeye integration will pull client information from Smokeball once a day from the closed matters of the previous day. Birdeye collects the following information about the client:
  • First name
  • Last name
  • Email address
  • Phone number
Birdeye will automatically send them review requests based on the preferences set within the Birdeye dashboard.
Set up the Birdeye integration
To set up the initial part of the integration with Birdeye, please contact Birdeye Technical Support at 1300 423 618 (Ext. 3) or send a request on their Contact page.
Specify to the technical support team if you wish for Birdeye to trigger fetching client data based on Open matters or Closed matters.
Once the team has set this up:
  1. Log in to Birdeye and navigate to the Settings tab on the left navigation panel of the Birdeye dashboard.
  2. Select Business Profile under the Profile section, then click on the specific location for which you have set up the integration.
  3. Scroll down to CRM Integrations, then select Authorize Smokeball.
  4. Log in with your Smokeball username and password, then select Sign in.
After signing in successfully, the CRM Integrations section will show the word Authorized next to Smokeball.
How to get help with the integration
For any help or support related to the Birdeye Integration, please reach out to Birdeye's support team by visiting their website.
0 out of 1 found this helpful
