Delete a matter
Learn how to delete a matter in Smokeball that was created by accident.
When a matter is marked as Deleted, it will not be permanently deleted in Smokeball, for audit log purposes.
Smokeball Desktop App
  1. Open the matter you wish to delete, then click on the File tab.
  2. Select Delete and confirm you wish to delete this matter.
View deleted matters
To generate a list of all matters that have been deleted:
  1. Navigate to the Matter List.
  2. On the top-right corner, select the Filter dropdown menu. Select the Status dropdown menu and tick Deleted.
Alternatives to deleting a matter
If you prefer not to have matters sitting in the Deleted matters view, consider reusing the matter by editing it or changing the matter type.
2 out of 7 found this helpful
