Add a matter type as a favourite
Smokeball allows you to set your most commonly used matter types as favourites for quick access.
Adding a matter type to your favourites list
  1. In the Smokeball Desktop App, select New Matter.
  2. Select the New Matter tab or Templates tab, wherever the matter type is located.
  3. Open the folder to locate the matter type, then click on the star icon.
All matter types and templates that have been starred will then appear under Favourites on the top of the window.
Removing a favourite matter type
Remove a favourite matter type from the list by right-clicking it and selecting Remove from favourites.
9 out of 11 found this helpful
