Dynamic Connect Integration
Learn how to connect Smokeball with Dynamic Connect to manage your scanning and copying needs.
Dynamic Connect is a cost recovery solution that allows you to charge for copy, print, scan, telephone, email, couriers and travel disbursements. Learn more about Dynamic Connect from their website.
The Smokeball integration with Dynamic Connect allows you to scan direct to Smokeball from almost any photocopier directly, or capture images from your mobile phone to send as a document to a matter.
Getting started with Dynamic Connect
To implement Dynamic Connect for your firm, contact the team at sales@dssolutions.net.au or call +61283381255 for a consultation. Pricing will vary according to modules required and features enabled.
How Dynamic Connect works
The Dynamic Connect team will manage installation requirements, including requesting your firm to authenticate Smokeball with Dynamic Connect. They will also collaborate with your photocopier supplier, telephone system vendor and IT to integrate solutions as required.
Once Dynamic Connect has been authenticated, matter data can be displayed on photocopiers and desktop pop-ups. Transaction information from Dynamic Connect can also be posted to Smokeball, with resulting transactions appearing on Smokeball invoices.
How to get help with the integration
If you have any questions about the Dynamic Connect integration or need assistance with its features, contact their support team between 8:30 am - 7 pm AEST/AEDT at support@dssolutions.net.au. You can also call them at +61283381255 or 1800 773 391.
0 out of 1 found this helpful
