Learn how to connect Smokeball to Zapier to take the automation of tasks in your firm to the next level.
Zapier is an application that delivers the power of automated tasks without requiring any experience or technical skill. You can use Zapier to direct Smokeball to copy and paste information to any one of Zapier's 5000 other app integrations. It is a way of building workflows and accomplishing simple tasks.
Learn more about Zapier and the apps they connect to from their website.
Zapier has also put together a Quick-Start Guide to creating your first Zap.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Zapier (https://zapier.com/).
Connect Smokeball to Zapier
- Log in to Zapier and navigate to App Connections on the left menu.
- Select Add connection.
- Type Smokeball into the search field and select it from the results.
 - A new window will open to confirm your region.
 - Log in with your Smokeball credentials.
Once you have connected your Smokeball account username and password, Smokeball will be listed among the other apps you’ve connected to Zapier and you’ll be ready to create Zaps using Smokeball triggers and actions.
Create a Zap with Smokeball Triggers
- Select Create from the left menu on Zapier, then select Zap.
 - Click on the Trigger and select Smokeball from your top apps, or alternatively find it using the search bar.
 - Choose an event from the Trigger event drop-down menu. Then, select Continue.
 - Select Test trigger to verify that the connection between Smokeball and Zapier is working.Â
 - Once you are ready to continue, select Continue with selected record.
- Continue to create the rest of your Zap and publish it once done.
Create a Zap with Smokeball Actions
 - Fill in the details for your Trigger event from the other app you are connecting to this Zap.
- Click on the Action and select Smokeball from your top apps, or alternatively find it using the search bar.
 - Choose an event from the Action event drop-down menu. Then, select Continue.
- A list of fields will appear, depending on the event you have chosen. Enter the relevant information, then test out your Zap.
Supported Smokeball triggers and actions
Currently, the Smokeball app contains the following triggers and actions:
| Trigger Events | Action Events |
