Smokeball Web App troubleshooting guide
Use this troubleshooting guide to resolve issues with the Smokeball Web App, which powers Smokeball Bill, Smokeball Boost and the Grow/Prosper+ web app products.
Use Google Chrome or Microsoft Edge
The Smokeball Web App runs best on Google Chrome and Microsoft Edge. Using other browsers may cause performance and display issues.
Replicate the issue in an incognito window
Issues with data syncing or discrepancies in your billing may be caused by the cookies saved to your Google Chrome browser. Check if the issue fixes itself when logging in to the web app via an incognito window:
  1. In Google Chrome, select theĀ three dots on the top-right corner of the browser, then click onĀ New Incognito Window. Alternatively, pressĀ Ctrl+Shift+NĀ on your keyboard.
  2. Open https://app.smokeball.com.au/ in the incognito window and log in with your details.
  3. Check if the data sync or discrepancies in billing figures have resolved themselves in the incognito window.
Delete Smokeball Web App cookies
If the Smokeball Web App displays data correctly in the incognito window, then you will need to delete the Smokeball web cookies from your browser:
In Google Chrome
  1. In a regular Google Chrome browser, select theĀ three dots on the top-right corner, then click onĀ Settings.
  2. SelectĀ Privacy and security from the left panel, then selectĀ Third-party cookies.
  3. Click onĀ See all site data and permissions.
  4. Search for "smokeball.com.au" in the search bar. Then, click on theĀ smokeball.com.au entry and delete the entry for app.smokeball.com.au.
  5. Close and reopen Google Chrome. Log back into https://app.smokeball.com.au/ and check if the issue has been resolved.
In Microsoft Edge
  1. In a regular Microsoft Edge browser, select the three dots on the top-right corner, then click onĀ Delete browsing data.
  2. In theĀ Delete browsing dataĀ window, select All Time under Time Range.
  3. Ensure only Cookies and other site dataĀ andĀ Cached images and files are ticked.
  4. ClickĀ Clear now, then close and reopen Microsoft Edge.
Further troubleshooting
If the issue persists after deleting Smokeball Web App cookies, try the following steps:
  • Perform a hard refresh of Google Chrome by holding Ctrl+F5 with the web app open.
  • Disable any third-party extensions such as ad-blockers. Do not disable any Smokeball Chrome extensions.
  • Log out and log back into the web app.
As a last resort, contact Smokeball Support to conduct further troubleshooting, such as gathering console logs and hardware information.
0 out of 2 found this helpful
