This month, we have released some new features in Smokeball Boost. Read on to learn more.
New features
Enable Two-Factor authentication
You can now set up two-factor authentication (2FA) entirely from Smokeball Boost.
To get started:
- Select the gear icon on the top-right corner, then select My Preferences.
- In the Account Security section, select Enable 2FA.
- Follow the prompts to set up two-factor authentication.
Learn more about setting up two factor authentication in Smokeball.
New Report - Rate Type by Matter
You can now run the Rate Type by Matter report to see which rates are attached to each matter.
Columns in this report:
- Matter Open Date
- Matter Number
- Client
- Matter Type
- Matter Description
- Person Responsible (this displays their initials only)
- Introducer (this displays their initials only)
- Rate Type
- Types
- Matter
- Staff
- Rate Set
- Types
- Rate Set
- Should only have a value if the Rate Type belongs in a Rate Set
Filters in this report:
- Report Period:
- Options:
- Show All Matters
- Custom Range
- Options:
- Matter Opened From
- Defaults to the First day of current year
- Matter Opened To
- Defaults to the Last day of current year
- Select one, multiple or all
- Defaults to All
- Introducer
- Defaults to All
- Matter Status
- Defaults to Open
- Billing Type
- Defaults to Time Based
- Rate Type
- Defaults to All
- Client Search
- Client Filter
- Save Filters as Firm Default?
- Defaults to No
