How to generate Intake Forms using Archie AI
Learn how to create a Lead or Matter Intake Form from scratch using Smokeball AI.
The Smokeball AI feature (aka Archie) is available as a paid add-on for all firms currently subscribed to Boost, Grow, or Prosper+ plans. If you are interested to learn more about our AI feature capabilities and pricing, please reach out to your Customer Success Manager.
To get started:
1. Navigate to Intake Forms in the Smokeball Desktop App or Web App.
2. Select the Create form button.
3. Choose Matter or Lead.
4. Enter a name for the form, the relevant state/s, and the appropriate matter type/s.
5. Select Create form.
Smokeball AI will generate a template Intake Form based on the state/s and matter type/s selected.
Convert an existing form into a Smokeball Intake Form
Alternatively, you can convert an existing paper form into a Smokeball Intake Form using AI.
5. Select Upload and convert an existing form.
6. A section will appear that allows you to upload a copy of the form. Drag the .PDF, .JPEG or .PNG copy of the Intake Form into the box or select Browse to select it from your computer's hard drive.
7. Once the file is uploaded, select Create form.
7 out of 7 found this helpful
