The Divorce (WA) matter type provides the necessary contact cards and layouts for an application for Divorce in the Family Court of Western Australia. Create a separate matter for advice about parenting or property arrangements.
You can select whether you act for the Applicant or the Respondent.
The following Contact Cards and Layouts appear by default on a Divorce (WA) matter:
- Applicant and Applicant’s Solicitor (as applicable).
If it is a joint Application for Divorce, you can add another Applicant and leave the Respondent contact card blank. - Respondent and Respondent’s Solicitor (as applicable)
- Relationship Details
Enter the parties’ cohabitation, marriage, separation and divorce details.  - Case Details
Enter the details of the court proceedings. Â
Uncommon contact cards are also available for selection on a matter-by-matter basis, such as:
- Child
- Process ServerÂ
- Subpoenaed PartyÂ
Precedent Library
The Divorce (WA) matter provides access to the Family (WA) Precedent Profile. This pre-set Precedent Library folder contains non-legally drafted precedents for everyday use, together with shortcuts to commonly used documents found under Court & Authority forms:
Recent Updates
The Western Australia Children Matter Type was recently converted from a Non-Localised Matter Type to Western Australia Localised Matter Type. Please see our What to expect when Smokeball localises a Matter Type to see how these changes may apply to you.
