Law Tram Integration
Plan_BoostGrowProsper.svg
Learn how to integrate Smokeball with Law Tram, allowing you to push matter details from Law Tram to Smokeball.
Law Tram is a legal software that connects individuals and businesses with licensed Australian lawyers that best suit their needs. Learn more about Law Tram on their website.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Law Tram (https://lawtram.com.au/).
Connect Law Tram to Smokeball
  1. Log in to your Law Tram Partners Portal and select Integration.
  2. Click on Smokeball and select Connect now.
  3. Enter your Smokeball login details and select Sign in.
  4. Upon successful login, you will be directed back to Law Tram, and your connection date and time will appear on the Smokeball integration page.
Push a Law Tram matter to Smokeball
Once you have connected Smokeball to Law Tram, you can select the Law Tram matters you wish to send to Smokeball.
  1. From the Matters page, click on View Matter next to the matter you wish to send to Smokeball.
  2. Click on the orange Smokeball->Create Matter button.
  3. Select the Practice Area from the Category drop-down menu, then select the Matter Type.
  4. Select Synchronise to Smokeball now.
  5. Once the process has been completed, a success message will appear. Select OK.
In Smokeball, the matter and contact details will be created, and a copy of the Client Brief can also be accessed from your matter's documents.
1 out of 1 found this helpful
