Microsoft Integrations for Smokeball Boost
Plan_Boost.svg
Smokeball features several powerful integrations with Microsoft products to enhance your productivity. Keeping track of all these options can be challenging, so we have written this article to provide you with an overview to help you get started.
Microsoft products available and supported plans
Refer to the following table for a quick summary of Microsoft products and their compatibility with Smokeball Boost.
Smokeball Boost is built for the web, designed to work with Microsoft 365 web apps, including:
  • Word for the web
  • Word for desktop (Not to be confused with Microsoft Office Word)
  • Outlook for the web
  • "New" Outlook for desktop (officially called Outlook for Windows)
Microsoft 365 explained
Microsoft 365 is a way to pay for popular Microsoft applications through a paid subscription model. The subscription provides regular feature updates and benefits such as cloud computing storage. Many Microsoft 365 applications can be installed directly on your hard drive or accessed through your web browser.
Outlook and Smokeball Boost
You can use Outlook on the Web or Outlook for Windows (commonly referred to as "New" Outlook) with Smokeball Boost. Read this guide to learn how to connect your Outlook account to Smokeball Boost.
Outlook calendar and Smokeball
Aside from emails, Smokeball also syncs with Microsoft 365 Outlook calendars. This two-way sync allows you to manage your events either in Outlook or in Smokeball Boost.
Once you have synced your Smokeball user account with your Outlook calendar, you will be able to set up meetings and events in any Smokeball matter or within your Outlook calendar view and have them automatically sync so your calendar stays consistent across both platforms. Any changes to calendar events will also update in Smokeball and Outlook.
Learn how to view and create events in Smokeball Boost.
Word and Smokeball Boost
You can also link the Microsoft 365 Word desktop app or web app with Smokeball Boost. Once linked, you can easily create letters from within your matter.
1 out of 1 found this helpful
