Learn how to connect Smokeball to Odella (formerly known as Lawme), an AI-powered workforce factory for automating tasks, research and document drafting.
To find out more about Odella and book a demo, get in touch with the team via their website.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Odella (https://www.odella.ai/).
Connecting Smokeball to Odella
- Log in to your Odella account and select Integrations from the left menu.
Toggle on Smokeball from the list of integrations.
- Follow the prompts to log in to your Smokeball account in order to authenticate the connection.
Using the Odella Integration
Once Smokeball is connected to Odella, you can connect Smokeball data to a Workflow in Odella, for your AI employee to follow.Â
These Workflows can be as simple or complex as you need, even incorporating Odella's Templates to draft documents using AI.
You can also direct your AI employee to look up Smokeball matter data via the Chat feature.
Â
