Learn how to use Smokeball with Umango, allowing you to export job documents from Umango into Smokeball.
Before you begin
Ensure you have connected your Smokeball firm to Umango. Refer to Umango's listing on the Smokeball Marketplace or the Umango website for more information.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Umango (https://www.umango.com/).
Using the Umango Integration with Smokeball
Watch the comprehensive video below on how to connect your Umango job to Smokeball.
