Workzilla Integration
Learn how to connect Smokeball to Workzilla in order to utilise Workzilla's comprehensive reporting features to gain business insights.
Logo
Learn more about Workzilla on their website, including signing up for a free trial.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Workzilla (https://workzilla.co/).
Using Smokeball with Workzilla involves signing into your Workzilla workspace with your Smokeball login credentials:
  1. Navigate to the Workzilla Free Trial page.
  2. Click on Smokeball from the Choose your integration section.
  3. Enter your Smokeball email and password and select Sign in.
  4. You will be redirected back to Workzilla. Create a password for your Workzilla account and select Save.
  5. Your firm's data will then begin syncing, then Workzilla will compile all your data into dashboards. This could take up to 45 minutes for a medium-sized firm.
    You will be notified via email once all data has been set up.
  6. Once all data has been synced and dashboards created, you can start inviting other staff members to your Workzilla space, set up teams, or create targets.
