Learn how to connect Smokeball to Firehawk Analytics to analyse your firm's financial performance.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Firehawk Analytics (https://firehawkanalytics.com.au/).
Connect Smokeball to Firehawk Analytics
To get started:
Navigate to the Firehawk Analytics signup page and enter your firm details. Then select Create workspace.
Navigate to Admin on the bottom-left corner of the screen and select Integrations.
Click on Smokeball from the list of integrations and select Connect Smokeball from the right-hand panel.
- Follow the prompts to log in with your Smokeball credentials.Â
Once you return to Firehawk Analytics, toggle on Legal Practice on the right-hand panel. Your data in Smokeball will then start syncing to Firehawk Analytics.
You can track the progress of the data sync by selecting Track Data Refresh.
Once the data sync is complete, the Last Run Status will update to Success. Refresh the page to see how long the sync took under the Last Run Duration column.
Using Firehawk Analytics dashboards
Once you have connected your data to Firehawk Analytics, select Management from the left menu. You will be presented with two dashboards to view either Performance at a Glance or Lawyers at a Glance.
This dashboard gives you a high level overview of how your business is tracking.Â
You can drill in to more detail by viewing the Lawyer Analysis and Efficiency & Distribution tabs that go into more detail on each staff member.
Lawyers at a Glance
This dashboard is where invited staff members can go to track their own performance and metrics.
Clicking on a staff card displays a summary of their performance. You can also view their events on the Calendar tab, or the matters they are working on via the Matters tab.
Refreshing your data
You can re-sync your Smokeball data with Firehawk Analytics at any time by navigating to Admin on the left-hand panel, then selecting Data Refresh. Click on the Play icon on the right-most column to start syncing.
