The Re: Line in Smokeball can be customised for different matter types.
- To create a default customised Re: Line access the Smokeball Settings
- In the settings select Matter Configuration (1), then Add New (2)
- Note: If you already have Matter Configuration set up for this matter type, double click on the matter type displayed (3) instead of Add New
- The system will automatically display the RE:LINES tab (1), Select a matter (2), select the Matter Type (3) and OK (4)
- Search for the specific fields you require in the Re: Line (1), select Insert to add the field (2), add any additional information as required (3) and Save (4)
Did you know…
- To override a matter type Re: Line for a specific matter, select Override in the Matter Details Re: Line dialog box and enter the required information for the Re: Line
Didn't find what you needed? Need more help? Contact Us for assistance
