Learn how to share your matter stages with other Smokeball users by using the Import and Export feature.
Export matter stages for sharing
- Select the Settings (gear) icon on the top-right corner of Smokeball.
- Select Matter Stages from the left menu.
- Right-click on the matter stages you wish to share, then select Export.
- Select the folder on your computer where you wish to save the matter stages. They will be saved as a .zip file. Do not open/extract the .zip file!
Import matter stages into Smokeball
- Right-click anywhere in the matter stage list, then select Import.
- Find the .zip file on your computer, select it, and then click Open.Â
