Export Smokeball data
Learn how to generate a .csv file of all your matters and clients, or in some cases, your matter documents and files as well.
Exporting CSV Files of your Matters and Clients
  1. Select Reports from the left menu.
  2. From the drop-down menu, select Matter - Summary List (to export matters) or Contact Export (to export contacts).
  3. Use the filters to drill down on the data further, then select View Report, located on the right-hand side.
  4. Select the Floppy disk icon and click on CSV (comma delimited).
  5. Once the CSV has been downloaded, select Open. Alternatively, open it later from your computer's Downloads folder.
Export documents saved in matters
Send a request to our Support Team
The documents will take up to 5 business days to prepare. You will be sent an email with a Link to download the data.  This will appear as a folder for each matter,  and each folder will contain the documents.
4 out of 18 found this helpful
