Enter box, customer and licence numbers in Smokeball
Learn how to enter credentials such as lawyer's code and state-based identification numbers in Smokeball Settings.
Follow the steps below if you need to enter any of the following:
Federal
  • Lawyer's code
NSW
  • LRS Box Number
  • LRS Customer Number
  • Revenue NSW Client ID
QLD
  • Land Registry Lodger Number
  • OSR Client Number
SA
  • LTO Agent Code
VIC
  • Firm LSB Number
  • LTO Customer Code
  • LTO Form APA Approval Number
  • LTO Form APR Approval Number
  • LTO Form ASP Approval Number
  • LTO Form MCP Approval Number
  • LTO Form M1A Approval Number
  • LTO Form M1B Approval Number
  • LTO Form T2 Approval Number
  • LTO Form T3 Approval Number
  • LTO Form A1 Approval Number
  • LTO Form L Approval Number
Enter numbers
  1. Select theĀ Settings (gear) icon from the top-right corner of Smokeball.
  2. Navigate toĀ theĀ FirmĀ Details tab in the Smokeball Settings window.
  3. Scroll to the bottom of the section to findĀ Box, Customer & Licence Numbers.
    • By default, it will display the relevant numbers for your firm's state. Select the drop-down menu to chooseĀ Federal or other states.
  4. Click on theĀ Number field next to the number you wish to add, then start typing the number in.
  5. SelectĀ Save.
2 out of 2 found this helpful
