Learn how to set up the FamilyProperty Integration with your Smokeball firm.
You will only need to complete this process once, and one person will authorise the whole firm to use the integration.
- Select the gear icon on the top right-hand corner of the Smokeball desktop app to open Smokeball Settings.
- Select Integrations from the left menu, and click on FamilyProperty.
- Select Authorise and follow the prompts to connect your account.
- Select Save to exit Smokeball Settings.
- (Recommended) Fully close and reopen the Smokeball desktop app.
Once you've successfully connected the integration, you can use FamilyProperty features in Smokeball.
Visit the FamilyProperty Knowledge Base to learn more:
