Learn how to connect Smokeball to your Realaml account in order to run KYC and CDD verification on your contacts in Smokeball.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Realaml (https://realaml.com/en-AU/s/home).
Connecting Smokeball to Realaml
- Log in to Realaml and go to the Integrations tab.
- Click Connect next to Smokeball.
- Enter your Smokeball login credentials to complete the connection.
Running a Verification
- Navigate to the Run Checks tab.
Select your preferred verification type.
- Use the Smokeball field to search for a Matter Number or Matter Description.
- Select the matter. Matter Contacts will automatically import.
- Review the prefilled contact details, adding any missing information (e.g. Date of Birth).
- Check the Consent box and click Run Check.
- Repeat from Step 1 to verify more clients.
Accessing Verification Reports in the matter
Once verifications are complete, access your reports in Smokeball:
- Open Smokeball and select the relevant Matter.
- Click on All Files—you’ll see the Realaml verification PDFs stored here.
- Go to Time & Disbursements and click on the Disbursements tab to view the verification costs.
