RedView CRM Integration
Learn how information in Smokeball is displayed in your RedView CRM instance.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to RedView (https://www.redraincorp.com/business-intelligence).
Connecting Smokeball to RedView
Access to RedView is granted when your firm purchases the software. The RedView team will set up your firm's database in the system and send you an email to log in.
Once logged in, authenticate with your Smokeball login details to start the data sync from Smokeball to RedView.
How Smokeball data appears in RedView CRM
Client management
The best way to get the most out of the RedView integration is to treat your Smokeball contacts as the source of truth; what RedView CRM does is allow you to record more information against those existing contacts, such as:
  • A profile picture, relationship manager and importance level
  • Recording notes and follow-up tasks that can be assigned to a staff member
You can also click on any contact record in RedView to get a client-centric view of their:
  • General contact information
  • Related matters in Smokeball
  • General performance using a customisable dashboard (useful for commercial clients)
    Referrer management
    Like client contacts, RedView CRM also syncs your Referrer contacts from Smokeball as a source of truth.
    Clicking on a referrer record allows you to view more information, such as the matters referred, and a customisable referrer dashboard.
    Lead enquiry management
    When adding a new enquiry into RedView CRM, the system will check for duplicate contacts that may exist in Smokeball.
    When the lead in RedView is converted to a matter, you can enter the matter information directly from RedView. Upon saving, a new matter will be created in Smokeball.
    Marketing
    In RedView CRM, you can group Smokeball contacts into lists for marketing purposes and campaigns, or simply to export them to a spreadsheet.
