Smokeball allows you to set your most commonly used matter types as favourites for quick access.
How to set a matter type as favourite
From Home Screen select New Matter (1)
Locate the matter types (2) and click to highlight the stars (3). All matter types and templates that have been starred will then appear under Favourites on the top of the screen (4)
How to remove a matter type as favourite
Either click on the star again to remove the highlight, or right click on the matter type to be removed (5) then Remove from favourites (6)
