QLD - Transfer of Land
To create a new Transfer matter, follow the steps below:
  2. Select State: QLD
  4. Select Matter Type: Transfer
  5. Select which party you are acting for (Transferor or Transferee):
  7. Select 'Property Details' to enter the Address, Property Details, Contract Details and Tenancy Details. Click on the Title Particulars tab to enter the title details.
  8. Select Transfer Details to input the Consideration and Market Value. The Stamp Duty will automatically be calculated once the Consideration and Market Value has been input. You can use this page to apply any concessions or grants if applicable.
  9. To add Uncommon Contacts to your matter, open the Matter Settings and select the appropriate contact from the Parties & Data available for your matter.
