Scan documents into Smokeball
If you have a local scanner or a scanner that is plugged directly into your computer (like ScanSnap), you can scan documents directly to your Smokeball matters.
We do not support Multi-Function Centres or network-connected scanners. If you utilise an MFC or a network scanner where documents are emailed or sent to a shared drive, import Documents and Folders instead.
  1. Make sure a scanner is connected to your computer.
  2. Open your matter and then select the Scan button.
  3. Select the scanner you wish to use in the pop-up window.
  4. Select the source of the scan (if applicable to your scanner) and then select OK.
  5. Once the scan is finished, complete the prompt asking you to name the file. You can also convert the file into a PDF. If you don't tick this option, the file will be saved as an image.
Video guide
7 out of 30 found this helpful
