Employment Contract
 To create a new Employment Contract matter, follow the steps below.
  2. Select the State of your Employment matter.
  3. Select Matter Type: Employment Contract.
  4. Select which party you are acting for (Employer or Employee)
  5. Enter your client details, and any relevant other parties:
    - See Adding Contacts for more information on adding contacts generally.
  6. To add Uncommon Contacts to your matter, open the Matter Settings and select the appropriate contact from the Parties & Data available in your matter.
  7. Open Info to change the Re Line or Matter Description of your Employment Contract matter. Select Override to type a new Re Line or Matter Description:
Change existing General matter to Employment Contract
Existing General matters can be easily changed to Employment Contract as follows:
  1. Open your existing General matter (used for Employment Contract)
  2. Open Matter Type
  3. Select change...
  4. Select new Matter Type as Employment > Employment Contract
  5. Select OK:
  6. Select which Party you are acting for (Employer or Employee)
  7. Enter Reason For Change
  8. Select OK:
Your matter will now appear as 'Employment Contract', with the party roles and layouts that are available in the Employment Contract matter:
Commonly Used Forms and Precedents
  1. Fair Work Information Statement
  2. Casual Employment Information Statement
  3. Letter to Employer enclosing draft Contract
  4. Letter to Employer enclosing Contract for Execution
0 out of 1 found this helpful
