Smokeball features many powerful reports which can be used to optimise your firm’s work routines, keep track of your deadlines, or maintain strong relationships with your clients.
Smokeball provides over 50 reports and dashboards for productivity, billing, and firm insights data. The following list outlines the available reports you can access upon joining Smokeball.
Accessing Smokeball desktop reports
To view reports on Smokeball desktop:
- Select Reports from the left menu.
- Select the report you want to run and add filters to customise it.
- After generating a report, you can export it by saving it to your computer in various file types, such as .CSV or PDF. You can also print the reports.
List of Smokeball desktop reports
Click on each heading below to view an expanded list of all reports we offer.
Business - Completion Report
This report provides a detailed overview of completed matters within a specified date range.
Results can be filtered by specific firm branch, and some data can be excluded by using the 'Included Columns' filter.
Matter - Full List
Use this report to generate printer-friendly readouts of all your matters.
- You can filter the report by the person responsible and the person assisting (Primary and Other), which cannot be done when exporting your matters from the Matters tab.
- You can also filter for multiple matter types, set a date range filter, and even organise your reports using your custom tags.
- The report allows for filtering by specific firm branch and State, and report data can be included/excluded by using the 'Included Columns' filter.
Matter Referral List
This report shows your matter’s referrals. This report also includes a billing amount column which can be used to help calculate referral fees. You can apply date range filters and use the Group By filter to organise the report by referral type or referrer.
Matter Archiving
Use this report to generate a list of closed matters that have been archived.
Matter - Next Steps
Run this report to generate an overview of the progress of all your matters based on the current task and/or workflow step.
Matter - Next Task
This report has been designed to track the upcoming task for each matter. It helps firms track deadlines and manage workloads, with options to filter by due date, matter type, referral type, or assignee, and to group results as needed.
Matter Summary List
With this report, firms will be able to see a full list of their matters, including details on the current status of each matter and the next steps.
Matter Turnaround Time
This report enables firms to track the time it takes to close a matter by identifying the number of days that have elapsed between its opening and closure.
Client - Full List
Use this report to generate a printer-friendly readout of all your clients. You can apply filters to sort the report by date opened, matter type, city, or county.
Client Birthday List
Use this report to view all your clients’ birthdays if you wish to send them cards or gifts. We advise always setting the Date Opened From filter to the day your firm started using Smokeball to ensure that all your clients are included. Clients who are deceased will not be included.
Client Verification of Identity
This report generates a list of client names that either have a set VOI date and/or not, and allows you to filter them to see only overdue ones, ones due shortly (2 months and 4 months), or to see all. You can also modify the report to exclude certain columns of data via the 'Included Columns' filter.
Client without Verification of Identity (Available upon request)
Easily generate a list of all clients without a Verification of Identity.
Will Register
Sorted by matter number, this report displays the clients' full name, date of birth, document received date and matter closed date.
Contact Export
Export a list of all person and organisation contacts in Smokeball. Your list is able to be filtered by Contact tags, Referral type, and the inclusion of deleted contacts, if needed.
This report is similar to the matter and contact full list reports but limited exclusively to your leads. Also available via web app.
Lead - Closed Lost
This report shows you all the leads that have been closed or lost along with the reason.
Lead - Open and Next Steps
This report is similar to the matter next steps report, but it is exclusive to leads.
Lead - Referral List
This report shows your lead’s referrals. This report also includes a billing amount column which can be used to help calculate referral fees. You can apply date range filters and use the Group By filter to organise the report by referral type.
Lead - Marketing Report
This report tracks the matter lifecycle from Lead to conversion to a Matter, allowing you to calculate conversion rates and cost estimates, how long it takes to convert Leads to Matters, and from that data identify any trends in the reasons why Leads don’t convert.
Conveyancing Settlements Report
Use this report to gain a comprehensive view of your Conveyancing matters' property settlement details.
Conveyancing Cooling Off Report
Use this report to gain a comprehensive list of cooling-off dates and the corresponding matters. This report can help your firm to keep track of cooling-off dates, prioritise workload and ensure your firm does not miss important deadlines.
Conveyancing Agents Report
Use this report to gain a comprehensive list of all Conveyancing agents and their corresponding matters.
Conveyancing Matters Report
Use this report to access a comprehensive overview of your Conveyancing matters and critical settlement dates. The report helps firms track the progress of each matter, from the initial contract/exchange date to the settlement date or auction date.
Conveyancing Stamp Duty Due Report
The Stamp Duty report allows you to generate a report containing a list of all Conveyancing matters containing Stamp Duty due dates and Stamp Duty amount.
Conveyancing Sunset Date Report
This report helps staff easily locate the Sunset dates in their Conveyancing matters.
Conveyancing Critical Dates Report (QLD)
This report is only relevant to QLD Conveyancing matters. This report allows you to view the most common critical dates for matters managed for this specific State.
Conveyancing Critical Dates Report (VIC)
This report is only relevant to VIC Conveyancing matters. This report allows you to view the most common critical dates for matters managed for this specific State.
Conveyancing Critical Dates Report (SA)
This report is only relevant to SA Conveyancing matters. This report allows you to view the most common critical dates for matters managed for this specific State.
Matter Referral Conveyancing Settlement List (Available upon request)
Use this report to generate a list of all the Conveyancing matters that have been referred to your firm. The report includes the Referral information, the Person responsible, and the Billed Amount.
Real Estate Agents - Emailing List
This report allows you to generate and export an email list of all Real Estate Agents listed in your Contacts, combined with agent and agency contact details.
Real Estate Agents - Full List
Use this report to generate a list of all Real Estate Agents and their contact details.
Anticipated Settlement Date - Personal Injury
This report is designed to provide insight into Personal Injury (PI) matters by showing the anticipated settlement date for each matter, helping firms with forecasting and workload planning.
Statute of Limitations
This report provides an overview of your Personal Injury matters and the statute of limitations dates.
Visa Expiry Date
This report is designed to provide you with a clear view of the visa status and expiry date of your clients' visas, making it easier to manage your immigration matters.
Register of Files Opened (also available via web app)
The Register of Files Opened report is designed to help firms in NSW and VIC comply with the requirements under the Legal Profession Uniform General Rules 2015 and the Legal Profession Uniform Law (Part 4.6 section 93) to produce a register of files opened.
AML Report
This report includes VOI (Verification of Identity) and other AML data, giving you a clear picture of AML compliance, including any contact-related AML information. Filter by staff to track progress across your team, or by Matter Status to focus on the matters you need. You can also add Street Address, Country, and Settlement Date through the Included Columns filter.
AML - Execution Report
This report is a more concise version of the AML Report, focusing on execution-related information for AML checks, and includes attorney details along with key AML fields.
Event List (also available via web app)
Use this report to generate a list of all upcoming events and their corresponding matters and/or leads. The report can group results by location, providing an organised view of events.
Safe Custody - Filtered
This safe custody report provides you with a record of all documents that your firm holds on behalf of clients and their storage information. It includes an option to search and filter by Client Name and Packet Number. Note that when searching for a client name, type at least 3 characters in the search text box.
Safe Custody Full List
Use this report to generate a complete list of all safe custody records.
Time Costing Report (Available upon request)
Firm owners can use this report to keep track of staff hours and their costs to the business.
Accessing Smokeball billing reports
On the Smokeball Web App, you can generate reports that manage all aspects of the billing cycle, including trust, invoicing, matter overview, and time/expense reports.
To view Smokeball billing reports:
- Select the report you wish to run, then use filters to customise your view.
- Once you generate a report, you can export it as a PDF or CSV file, or print it.
List of Smokeball billing reports
Click on each heading below to view all billing reports based on their report name in alphabetical order.
Aged Unbilled Disbursements
This report enables your firm to track and analyse unbilled cost recoveries as of a specific date, supporting audit, compliance, and financial management needs.
Aging Summary
The Aging Summary report displays all unpaid invoices as at a specific date and places them into aging buckets based on how long overdue they are. You can also see which invoices are not overdue ("Current" column). The invoices are grouped by client and matter. There is also an overall Aging Summary table at the end of the report that provides aging bucket totals for your firm.
Filters:
- The Report Date filter allows you to run the report as of a specific date of your choosing.
- The Person Responsible and Person Assisting filters give you the option to limit the results to specific individuals in your firm.
Billed Fees & Disbursements - Summary & Details
Shows billed fees and disbursements against areas of law, matter types, clients, timekeepers, referrers, or persons responsible.
Invoice History
The Invoice History report shows all invoices generated within a selected time period. Invoices shown in the report are grouped by client and matter. It includes all Accounts Receivable details of the invoice including Days Overdue, Interest, Paid amount, Credited amount, Waived amount, and Total Due.
Money Received
The Money Received report shows all funds received by your firm during a select period. This includes invoice payments, trust deposits, and operating retainer deposits.
Filters:
- This report includes the date filters Payment Date From and Payment Date To, which are required for the report to be run.
- The Person Responsible filter allows you to narrow down the data shown in the report to that of only specific staff members assigned as Person Responsible to a matter.
- It also has filters for Account and Source which allow the report to be narrowed down to a specific trust or operating account(s) or a specific payment type(s).
- The Branch filter allows you to narrow the report to only show data for a specific firm branch.
- The report also gives you control of how the report is grouped via the Group By filter which has options of None, Account, Source, Matter Type, Client, Received From, and Person Responsible.
Time and Disbursement Entries
The Time and Disbursement Entries report provides an overview of all time, fee, and disbursement entries during a select time period. The report has separate sections for Time and Fee Entries and Disbursement Entries and includes columns for non-billable, billable, unbilled, and billed entries.
Unbilled Time and Disbursements - Summary and Details
The Unbilled Time & Disbursements report has two versions. Use the Summary version to see the total unbilled time, fees, and disbursements for a selected period. Use the Details version to see each unbilled entry, so that you can decide which entries to bill and which to write off.
Unbilled and Unpaid Overview
Use this report to find out how much money you can move from your trust account to your operating account at any given time. By default, the report shows only matters that have a credit balance or a trust balance. To show all matters with an unbilled or unpaid balance, use the Include zero balance trust & credits filter.
Unpaid Invoices Billing Report
This report shows all of the current unpaid invoices regardless of the date of the invoice, providing an easy way to see which invoices remain outstanding and can be narrowed down or grouped.
Account Balances
The Account Balances report shows the balance and transaction history of a selected trust or operating account for a selected period of time. This includes total billed and paid, unbilled and unpaid, cash retainer, trust balance, write-offs, and discounts. Use this report to manage risk, improve cash flow, and see which accounts have funds in the operating retainer.
Account Statements
The Account Statements report is a robust report that includes several sections: Fees, Disbursements, Invoice History, Invoice Summary, Account Summary, Transaction History, and Account Ledger. This report gives you an overview of all the activity during a selected time period for a specific matter, or all your matters.
Filters:
- The Report Period filter allows you to limit the results to a specific time period or run the report for all time.
- The Show Invoices for filters allows you to run the report for either a specific matter, or for all matters.
- The View Options filters allows you to control which sections are included on the report, along with other display options.
Client - Full List (available on both web and desktop)
Matter - Full List (available on both web and desktop)
Use this report to generate printer-friendly readouts of all your matters. You can filter the report by the person responsible and the person assisting, which cannot be done when exporting your matters from the Matters tab. You also can filter multiple matter types, set a date range filter, and even organise your reports using your custom tags.
Matter Balances
The Matter Balance report provides a thorough financial overview of all your matters. It displays Trust Balance, Unbilled, Billed, Write Off, Discount, Surcharge, Interest, GST, Paid, Credit Applied, Waived, and Matter Balance.
Filters:
- This report includes filters for Person Responsible and Matter Status.
- You can view the report as either a single list of matters, or to group them by client.
- In addition, you can choose to exclude or include matters with $0 balances, incomplete matters, and externally billed.
Matters by Billing Type
The Matters by Billing Type report allows you to see all matters opened during a selected time period along with their billing type (e.g. fixed fee, contingency, time-based, etc.).
The report can be filtered by Date Range, Billing Type, Matter Status, Person Responsible, Person Assisting, Matter Category, and Matter Type.
Matter Category Paid History
The Matter Category Paid History report allows you to see payments received during a selected time period, grouped by matter category.
Rate Types by Matter
The Rate Types by Matter report allows you to see which rate type and/or rate set has been applied to matters.
Cash Book Payments
The Cash Book Payments report shows all payments made from your trust accounts.
Cash Book Receipts
A report showing all the trust deposits made within the selected report period.
Controlled Money Listing
This report is designed for law society compliance and will allow a firm to create a list of all Open Controlled Money Accounts at the time the report is run. This includes Open accounts that have zero-dollar balances. It's a way to create a quick audit/overview of current CMA accounts, their balance, and the matters they're linked to.
Dormant Trust Balances Report
This report provides a list of trust balances that are dormant or approaching dormancy.
Overdrawn
The Overdrawn report shows any overdrawn amounts in trust, by matter.
Filters:
- The Account filter allows you to limit the results to a specific trust account or include all accounts.
Potential Trust to Office
This report shows any matters that include outstanding invoices and a trust balance. This report can be used to review and manage Trust to Office Transfers.
Trial Balance
The Trial Balance report displays trust balances and last transaction dates per matter as at a selected date.
Trust Receipts
The Trust Receipts report shows all trust deposits received within a selected time period. It includes details including transaction date, entered date, receipt no., received from, matter, payment type, payment ref., amount, and status.
Trust Statements
The Trust Statements report allows you to create a trust transaction report for a single matter or for all matters during a selected time period. It is designed to assist with trust accounting compliance. When running the report for all matters, you will receive an email containing a secure link where the reports can be accessed. Access will be provided for 7 days from when the email was sent.
Credit History
The Credit History report shows all credits added and applied to your invoices and matters during a selected time period. You can run it either for a specific matter, or for all matters.
Income Allocation - Summary
The Income Allocation – Summary report shows income for a selected time period and allows you to see how that income is allocated to a variety of sources. This report can be used to assist with compensation plan calculations or to assess strengths and weaknesses in your business from an income perspective.
Income Allocation - Details
The Income Allocation – Details report shows income for a selected time period and allows you to see how that income is allocated to a variety of sources.
It can also be used to dig deeper into the details behind the summary level values in the Income Allocation – Summary report and verify that payments have been applied correctly.
Journal Transfers
Shows all the journal transfers made within the selected report period.
Ledger Export
The Ledger Export report shows all invoices and payments for a matter of contact within a selected time period. In addition, it provides a running ledger for any matter. You can use this report to see all the payments entered or which payments were included in any bank deposits.
Matter Cost Estimates
The Matter Cost Estimates report shows all time-based matters with estimates and how those estimates compare to the total billed and unbilled on the matter.
Time Adjustments - Details and Summary
Shows the write ups, write downs, and write offs to help you better assess where time differences are coming from. The report calculates write ups and downs by taking the difference between working hours and billing hours. Write offs are determined by the write off option on time and disbursement entries.
Audit Logs
The Audit Logs report displays creations, additions, deletions, and amendments to client and matter information in Smokeball Billing. It includes a Report Period filter that allows you to limit the results to a specific time period.
The following reports are also available in the desktop app.
Event List
Use this report to generate a list of all upcoming events and their corresponding matters.
Lead - Full List
This report is similar to the matter and contact full list reports but limited exclusively to your leads. Also available via desktop app.
Have a question about our reports?
If you can't find the information in the reports you need or would like to provide feedback, reach out to your Client Success manager or submit a ticket.
