Learn how to connect Smokeball to your Realaml account in order to run KYC and CDD verification on your contacts in Smokeball.
Connecting Smokeball to Realaml
- Log in to Realaml and go to the Integrations tab.
Click Connect next to Smokeball.
Enter your Smokeball login credentials to complete the connection.
Running a Verification
- Navigate to the Run Checks tab.
Select your preferred verification type.
Use the Smokeball field to search for a Matter Number or Matter Description.
Select the matter. Matter Contacts will automatically import.
- Review the prefilled contact details, adding any missing information (e.g. Date of Birth).
Check the Consent box and click Run Check.
- Repeat from Step 1 to verify more clients.
Accessing Verification Reports in the matter
Once verifications are complete, access your reports in Smokeball:
- Open Smokeball and select the relevant Matter.
- Click on All Files—you’ll see the Realaml verification PDFs stored here.
Go to Time & Cost Recoveries and click on the Cost Recoveries tab to view the verification costs.
