Smokeball Academy Overview
Welcome to the Smokeball Academy
The Smokeball Academy is a collection of online courses designed by our expert trainers which allow you to learn Smokeball at your own pace. Whether you are a brand new Smokeball user trying to master the basics or an experienced Smokeball user looking for a refresher on more advanced topics, the Smokeball Academy features courses to help you succeed.
Each course in the Academy is broken down into individual lessons comprised of step-by-step instructions, images, or videos. The Academy also features multiple learning paths tailored to your Smokeball product tier (Boost, Grow, and Prosper+). Learn more about each learning path below:
Smokeball Grow/Prosper+ Smokeball Boost Smokeball Bill
Starting off with Grow/Prosper+
All new Smokeball users on the Grow or Prosper+ tier should start with this learning path. Once you finish these courses, you can move on to the courses under the Billing with Grow/Prosper+ learning path.
  1. Smokeball Foundations: Basics
  2. Smokeball Foundations: Essentials
After you learn the basics and essentials, follow this learning path to discover how Smokeball will enhance your firm's billing processes.
  1. Introduction to Billing
  2. Bulk Billing with Smokeball
  3. Better Billing with Smokeball
  4. Trust Accounting in Smokeball
  5. Moving Your Client Balances to Smokeball (optional)
  6. LEDES Billing with Smokeball (optional)
  7. QuickBooks Online (optional)
  8. Split Billing in Smokeball (optional)
Once you have identified the learning path for you, log in to the Academy using your Smokeball username and password. You then can select the learning path on the Academy to get started.
Additional Help
Smokeball trainers are ready to help you through every step of your learning journey. If you have any questions while taking a course or after finishing a course, you can submit a ticket.
36 out of 61 found this helpful
