Getting Started With Smokeball Boost
Smokeball Boost is a browser-based practice management tier. Access your matters from any device or operating system, whether it's a PC or a Mac, an iPad, or a mobile phone. Your data is securely stored on our servers, so you can easily load matters on the go at any time.
What's included in Smokeball Boost?
Smokeball Boost features include:
If you are switching from a previous billing program, it is recommended to finish your ongoing billing cycle using the previous program. You should then transfer any outstanding balances and deposits to Smokeball before commencing billing with Smokeball.
Setting up your firm in Smokeball Boost
Upon signing up and logging in to Smokeball Boost, you will be presented with our Onboarding Wizard to set up your firm.
Confirm your Firm Name is correct (you can change this in Firm Settings later).
We will then look up your firm's address. Confirm if the address presented is correct, or amend if necessary.
We will also look up your firm's logo. Confirm if the logo presented is correct, or upload it from your files.
Next, set up your billing details by entering your Billing Rate ($) and Billing Units (minutes). This step is optional - you can enter the information later from Firm Settings.
  • Your Billing Rate is the dollars per hour you charge your clients.
  • Your Billing Units are the number of minute increments you prefer to bill your clients in.
Lastly, it's time to create your first matter. Enter your client's name, Matter Type and a brief description. You can also skip this step and create your matter later.
Now you can start using Smokeball Boost! With all these core settings filled in, you can get started with creating an invoice.
Learn how to use Smokeball Boost by taking a course designed by our expert trainers.
Getting Started with Smokeball Boost Webinar
This is a pre-recorded Getting Started with Smokeball Boost training webinar. You will learn your way around, how to administer matters, create contacts, work with documents and email, how to set up invoices, reports and more.
Smokeball Boost Open Office Hours
This is a live session (bi-weekly) in which two live trainers will be available to answer your questions. Drop in any time during the Office Hours window to ask your question(s) about Smokeball Boost- setup, reports, invoicing, trust accounting, e-signature, Outlook integration and more! All questions welcome. (Note: Times are Central Time.)
The second & fourth Thursday of every month - 11 a.m.
Additional Smokeball Boost Resources
To reach out to our Support or Training teams, please submit a ticket and select the appropriate request type from the dropdown menu.
17 out of 25 found this helpful
