Create a phone message
Use Smokeball's phone message feature to notify a staff member that someone called for them. This feature gives you the option to leave detailed notes and the option to notify the staff member by email.
Once created, a phone message will appear under your matter’s tasks, matter’s timeline, and Dashboard. More importantly, since a phone message creates a task, it is easier to track when someone calls a client back.
Smokeball Desktop Web App
Create a new phone message
  1. Select Phone Message from the Action Bar on the home screen or a specific matter.
    Note: the Matter will automatically populate in the Phone Message when opened from a specific matter.
  2. Select recipients using the Message for dropdown menu. It is possible to add multiple recipients.
  3. Enter the Caller's name. Smokeball will search your contacts and add details from the contact.
  4. Enter Organisation if applicable.
  5. Enter the caller's Phone number, if not already populated.
  6. Search and select the relevant Matter, if not already populated.
  7. Choose various message options and enter details of the call.
  8. Optional: Select the Notify via email checkbox to send email alert to the selected staff member recipients.
  9. Select Save.
View existing phone messages
Phone messages will appear in the the Daily Digest on your dashboard.
You can also view phone messages in your matter's Timeline and Tasks.
If you choose to Notify via email, the phone message will be sent via email to the selected recipients and look like the image below:
11 out of 19 found this helpful
