Conflict Checks
Learn how to use the advanced search to save conduct a conflict check and save the results to a matter. Advanced search looks at contacts, document titles and document content within Smokeball.
  1. Select Search from the left menu.
  2. Type the relevant name or phrase in the search bar.
  3. Results will populate, and you will see from this search you can see we have 1 Lead, 2 matters, 5 contacts and 26 documents that contain these words.  You can open each of these to complete your conflict check.
  4. Select Save Conflict Check next to the search bar to save a full report on the findings in this search.
  5. Choose the relevant matter in the new window.
  6. Type your conflict check assessment in Notes.
  7. Select Save.
A PDF document of the conflict check saves to the matter. The PDF contains the above Notes and a copy of the search results.
16 out of 21 found this helpful
