Import and export matter stages
Learn how to share your matter stages with other Smokeball users by using the Import and Export feature.
Export matter stages for sharing
  1. Select the gear icon on the top-right corner of Smokeball.
  2. Select Matter Stages from the left menu.
  3. Right-click on the matter stages you wish to share, then select Export.
  4. Select the folder on your computer where you wish to save the matter stages. They will be saved as a .zip file. Do not open/extract the .zip file!
Import matter stages into Smokeball
  3. Right-click anywhere in the matter stage list, then select Import.
  4. Find the .zip file on your computer, select it, and then click Open
