Send and manage Matter & Lead Intake forms
Learn how to use Smokeball Intake to collect data from your clients directly and automate this into your matter or lead.
Desktop (Grow/Prosper+)Web (Bill/Boost)
Send & manage a new Matter or Lead Intake Form on Desktop
Smokeball Intake contains forms tailored to the area of law your matter or lead is in. To get started with sending an intake form to your client:
  1. Open the matter or lead and select the Intake Forms tab.
  2. Select Share Form.
  3. Verify the details of the Contact and Email of the client. Then, select a form from the Form drop-down menu.
    The Form Preview window will automatically populate fields with information from the matter details if they have been filled in.
  4. Choose whether you wish to send this form via Communicate or email. Edit the message if needed.
    • Select the Custom Field icon to insert specific fields from your matter into the message.
    • You can customize this message for all matters in Smokeball Settings > Intake > Client Messages.
  5. Select Share to share as a Communicate message or Open Email if sending the form as an email.
Monitor Intake Form progress
Add the Intake Widget to your Dashboard to view the progress of intake forms across all your matters or leads. It can be configured to display a number of all forms or a list of forms.
Manage shared Matter or Lead Intake Forms
On the Intake Forms tab, you will see a list of all forms involving the client. Under the Last Modified tab you can track when the client has opened or started filling out the form.
Matter Intake Actions
Clicking on the three dots icon on the form will open up a list of actions you can take on the form:
  • View - access the form from the client's perspective.
  • Send Reminder -  send a Communicate or email message to the client as a reminder to complete the form.
    • You can customize this message for all matters or leads in Smokeball Settings > Intake > Client Messages.
  • Copy Link - copy the form's URL link
  • Edit Responses - edit responses on a shared form.
  • Close - close access to the form, if you have collated all relevant data.
  • Delete - delete the form. This can only be done if the Last Modified field shows "Not opened".
Send form responses to the matter
To view the responses that the client has entered so far, select View from the three dots icon.
If they have only partially completed the form, you can save the partially completed responses to the matter or lead by selecting the Save iconNote: Selecting Save Responses will overwrite any existing fields in the matter or lead.
Once the client completes the form, their responses will be automatically saved to the matter, and the Save icon will be disabled.
If the pre-configured matter intake forms do not meet your needs, you can also create custom matter intake forms
Send & manage a new Matter or Lead Intake Form on Web
    • You can customize this message for all matters in Settings > Firm Settings >Intake Forms > Client Messages.
Navigate to your global Intake tab to view the progress of intake forms across all your matters or leads. It can be configured to display a number of all forms or a list of forms.
    • You can customize this message for all matters or leads in Settings > Firm Settings Intake Forms > Client Messages.
6 out of 11 found this helpful
