Using the Data Import tool in Smokeball
Plan_BillBoostGrowProsper.svg
Get started on your Smokeball journey by importing all essential contact and matter data from your previous legal software or other sources.
What can be imported?
  • Staff
  • Contacts
  • Matters / Leads
  • Matter / Lead Tags (only available on Grow & Prosper+ plans)
  • Matter Roles (only available on Grow & Prosper+ plans)
  • Matter Critical Dates (only available on Grow & Prosper+ plans)
  • Matter Archive Details (only available on Grow & Prosper+ plans)
  • Matter Account Balances
  • Activity Codes
  • Unbilled Time/Fee Entries
  • Unbilled Expense Entries
  • Invoices
  • Billed Invoice Entries
  • Memos (not available on Bill plan)
  • Tasks (not available on Bill plan)
  • Calendar Events (not available on Bill plan)
A full list of supported fields can be found here.
Step 1: Preparing your source data
Prepare your source data to ensure a smooth upload and import process. To get started:
  1. Export the above-listed data from your previous software into any of the following file types:
    • CSV (comma-separated values)
    • XSLX (Microsoft Excel 2007 and later)
    • XLS (Microsoft Excel 97 to 2003)
  2. Follow the Preparing your source data for import article.
We recommend importing only relevant/active data, for example, minimising importing items such as "Closed" Matters / Leads and "Completed" Tasks where possible.
Step 2: Starting a new import
Once your data has been formatted as per the recommendations outlined in Step 1, you are ready to upload it to Smokeball.
  1. Select the gear icon in the lower-left corner of the Smokeball Web App, then select Data Import.
  2. Select New import.
  3. In the text box provided, select the system your data is coming from. If you can't find your system in the list, type a custom value, then select this option from the menu
  4. Choose the items to include in the import, then click Proceed.
  5. Select Upload under the data you wish to import into Smokeball.
  • Note: Some data types are unavailable (greyed out) until prerequisite data is uploaded and clear of errors.
  • Selecting Cancel import will discard all data under this import, allowing you to start over.
Once an import has been created, it will appear on main screen as In-Progress.
You can come back to this at any time before submitting the import.
Step 3: Mapping columns
Once a file has been uploaded, it is time to map the columns you have in the file with Smokeball's data columns.
  1. Select the row that is the header row in your source data. This step will be skipped if the tool can automatically detect the header row.
  2. Click Next.
  3. You will now be presented with the Map columns window. Under the Destination Columns section, use the drop-down menu to select a suitable destination field for each uploaded column.
    • The Sample Data column displays a preview of data from the corresponding column in the source data. (e.g. the Sample Data for the 'Last Name' column will extract Last Names from your source data).
    • The tool may automatically map some columns that it thinks will match with your data. You can change this by choosing another option from the Destination Columns drop-down menu.
    • Select Suggest mappings (not always available) at the top of the table to use AI-generated recommended mappings. We recommend reviewing the suggestions before proceeding.
  4. Click Next once done. You may only proceed if all Required Columns have been mapped.
An error message may appear if a required column has not been mapped, indicating the problem column that needs to be mapped.
If your source file does not contain a column that can be mapped to a "Required" Smokeball column, the following actions will need to be taken:
  1. Close the mapping view.
  2. Open your source data file (in Excel or similar) and add a column that can be used to map to the "Required" Smokeball column (the column name does not need to match the Smokeball column name).
  3. Re-upload the source file and proceed to map the columns.
Have issues with mapping columns? Review Preparing your source data for import to fix common pitfalls, then re-upload your file.
Step 4: Reviewing the uploaded data
Once mapping has been completed, all the data will be presented in a table. This view points out any validation issues in the data and allows you to edit the fields directly before saving the upload.
Any errors in the data are highlighted in red.
Any warnings in the data are highlighted in yellow.
The right-hand panel also shows a summary of all errors and warnings. Where a suggested fix is available, you can select Fix formatting errors to fix multiple errors in a column in bulk.
Click on the counter filter to filter the view by rows containing specific issues.
Click again to clear the filter and show all the data.
Some other useful tips to help navigate and edit data:
  • Filter tabs to the top right of the data to show clean rows/rows with issues.
  • "Find and Replace" button
  • Keyboard shortcuts:
    • Ctrl + Z = undo
    • Shift + arrows = select cells
    • Backspace or Delete = delete value from cell(s)
    • Ctrl + F = find a value
Additional rows can also be added directly from this view using the "Add Row" Button.
From this screen, you can Save a file upload.
You can save with errors and warnings still present and, if required, come back to continue fixing later. All errors must be fixed before the overall import can be submitted.
The Data Import screen will show a summary of any errors and warnings still present in the data.
At this point, you are free to close the tool and resume the in-progress import later.
To make any further adjustments, select Edit to reopen the uploaded data.
The overall import cannot be submitted until all data types are clear of errors (the import can be submitted with warnings). Refer to the summary of import errors from the import screen.
Repeat the above steps for every data type you wish to upload.
Matters / Leads & Matter / Lead Types
If importing Matters, an additional selection is required when uploading your Matter source file to indicate if you are importing matters within your firm's state only, or also other states.
The selection made here will dictate the Smokeball Matter Types shown to you when you reach the Matter Type mapping stage, where you will map your input Matter Types to those supported in Smokeball.
When mapping your input Matter Types to Smokeball Matter types, some Smokeball Matter Types have multiple "acting for" options, for example, Insurance Coverage - Insured and Insurance Coverage - Insurer. Where this is the case, you will see various options available for selection in the Smokeball Matter Type dropdowns and can select the most suitable choice.
In the above example, "IL" is the state, "Civil" is the matter type category, "Insurance Coverage" is the matter type, and "Insured" is the "acting for" role.
TIP: When mapping matter types, expand the column widths to get a better view of the dropdown options.
Step 5: Previewing & Submitting the import
Once you have uploaded, mapped, and fixed all outstanding errors across all data to be imported, you can preview and submit the import using the Preview & Submit button in the top-right corner.
Preview gives you a holistic review of your prepared import data before you submit it to your account, covering Staff, Contacts, Matters & Matter Type Mapping, Financials, and more. Each of these is shown in its own interactive, searchable, and sortable view, so you can quickly find and check the records you care about. Items such as Matters, Contacts, Invoices, Tasks, and Memos also have a detailed view, showing the full record along with any associated or linked records. A financial summary is also included at both an import-wide and matter level, so you can confirm the numbers are what you expect.
Use Preview to check that the data is accurate and complete, and to catch anything wrong while it's still easy to fix. If something's not right, you can fix it directly within the import tool using the Edit button on that item, or correct your source file and upload it again. You can repeat this correction-and-review cycle as many times as you need before submitting the import.
A few import items are not yet previewable, including matter roles, matter tags, and calendar events. If your import contains only items that are not yet previewable, you will see this submission confirmation pop-up, bypassing the ability to preview your import. Otherwise, you will be taken to the preview screen.
When you're ready to submit your import, click the Submit button in the top-right corner of the Preview screen. Then confirm in the confirmation prompt
Once an import is submitted, it cannot be reversed.
On the Data Import screen, the import status will change from In-progress to Submitted.
Once the import has been validated, the status will change to Loading.
Then Complete, and your data now resides in Smokeball.
Clicking "View summary" will show a count of data included in the import.
Troubleshooting
Validation
Once an Import has been submitted, if further validation issues are identified in the data, the status of the import will change to Failed Validation. A downloadable error file will be available to indicate the problem data, allowing you to re-open the current import, fix and any issues, then resubmit it.
Failed records
If an import completes but some records failed to load into Smokeball, the status of the import will be Complete and a downloadable error file will be available to indicate the failed records and reason for failure. Using the error file, a subsequent import can be performed for the failed records.
Unexpected
Once an Import has been submitted, if an unexpected system issue occurs, the status of the import will change to Failed Validation. If this is the case, please contact Support via the top right help (?) icon.
I need help with formatting and mapping my data.
Refer to Preparing your source data for import if you encounter any issues with mapping columns in the Data Import tool.
Supported Fields
Staff
Column Name Required/Optional? Notes
Staff ID
Required This is a unique identifier used for a Staff Member. This ID will not be visible in Smokeball and is an internal identifier only.
Title
Optional
First Name
Required
Middle Name Optional
Last Name
Required
Initials
Optional
Email Address
Required
Must be unique
Current Staff
Required
Is the staff member current/active (yes/no)
Contacts
Contact ID Required A unique identifier used for a Contact. This ID will not be visible in Smokeball and is an internal identifier only.
Type Required
Must be a "Person" or "Company" (Firm/Business/Organization). If not provided, where possible, this will be auto populated.
Full Name Optional
This field should not be mapped in conjunction with First Name/Middle Name/Last Name.
If used for mapping, the import tool will automatically split the full name out to First name, Middle name, Last name, or Company name.
Title Optional Title of the Contact
First Name Required if Type is "Person"
This field should not be mapped in conjunction with Full Name.
Less than 200 characters
Last Name Optional
Suffix Optional
Company Name Required if Type is "Company"
For "Company" type records, the name of the contact goes here.
For "Person" type records who are associated with a company/organisation, enter the associated company name here, as well as the person's name (in full name OR first/middle/last name).
Less than 200 characters.
Doing Business As Name Optional Optional. Can be used if a Company contact has a business name that differs to the company name.
Job Title Optional Job Title of the Contact.
Phone Optional Phone of the Contact (applicable to both `Person` and `Company` contacts).
Work Phone Optional Work phone of the Contact (applicable to `Person` contacts only).
Cell Phone Optional Cell Phone of the Contact  (applicable to `Person` contacts only).
Fax Optional Fax number for the Contact
Birthday Optional MM/DD/YYYY
Birth City Optional The birth city of the contact. Field not available on the Bill and Boost plans.
Birth State Optional The birth state of the contact. Field not available on the Bill and Boost plans.
Birth Country Optional Birth country of the contact. Field not available on the Bill and Boost plans.
Date of Death Optional Date of death (MM/DD/YYYY). Field not available on the Bill and Boost plans.
Death City Optional The city of death of the contact. Field not available on the Bill and Boost plans.
Death State Optional The state of death of the contact. Field not available on the Bill and Boost plans.
Death County Optional The county of the contact's death. Field not available on the Bill and Boost plans.
Death Country Optional Death country of the contact. Field not available on the Bill and Boost plans.
Gender Optional
E-mail Address Optional
Can take multiple (; separated).
Less than 255 characters.
Full Street Address Optional This field can be used if your input address data has multiple address parts (e.g. street/city/state/zip/country) combined on one line/in the same cell.
Care Of Optional Care Of details for the Address of the Contact.
This field should not be mapped in conjunction with Full Street Address.
Street Address Line 1 Optional Street Address Line 1.
Street Address Line 2 Optional Street Address Line 2.
City Optional City for the Address of the Contact.
State Optional State for the Address of the Contact.
Zip Optional Zip Code for the Address of the Contact.
Country Optional Country for the Address of the Contact.
Full Mailing Address Optional This field can be used if your input mailing address data has multiple address parts (e.g. street/city/state/zip/country) combined on one line/in the same cell.
Mailing Address Care Of Optional Care Of details for the Mailing Address of the Contact.
This field should not be mapped in conjunction with Full Mailing Address.
Mailing Address Line 1 Optional Mailing Address Street Line 1.
Mailing Address Line 2 Optional Mailing Address Street Line 2.
Mailing City Optional City for the Mailing Address of the Contact.
Mailing State Optional State for the Mailing Address of the Contact.
Mailing Zip Optional Zip Code for the Mailing Address of the Contact.
Mailing Country Optional Country for the Mailing Address of the Contact.
Full Registered Agent Address Optional Only valid for Company contacts. This field can be used if your input Registered Agent address data has multiple address parts (e.g. street/city/state/zip/country) combined on one line/in the same cell.
Registered Agent Address Care Of Optional Only valid for Company contacts. Care Of details for the Registered Agent address of the Contact.
This field should not be mapped in conjunction with the Full Registered Agent address.
Registered Agent Address Line 1 Optional Only valid for Company contacts. Registered Agent Address Street Line 1.
This field should not be mapped in conjunction with Full Registered Agent Address.
Registered Agent Address Line 2 Optional Only valid for Company contacts. Registered Agent Address Street Line 2.
Registered Agent Address City Optional Only valid for Company contacts. Registered Agent Address City
Registered Agent Address State Optional Only valid for Company contacts. Registered Agent Address State
Registered Agent Address Zip Optional Only valid for Company contacts. Registered Agent Address Zip
Registered Agent Address County Optional Only valid for Company contacts. Registered Agent Address County
Registered Agent Address Country Optional Only valid for Company contacts. Registered Agent Address Country
Full Forwarding Address Optional This field can be used if your input Forwarding address data has multiple address parts (e.g. street/city/state/zip/country) combined on one line/in the same cell.
Forwarding Address Care Of Optional Care Of details for the Forwarding address of the Contact.
This field should not be mapped in conjunction with the Full Forwarding address.
Forwarding Address Line 1 Optional Forwarding Address Street Line 1.
This field should not be mapped in conjunction with Full Forwarding Address.
Forwarding Address Line 2 Optional Forwarding Address Street Line 2.
Forwarding Address City Optional Forwarding Address City
Forwarding Address State Optional Forwarding Address State
Forwarding Address Zip Optional Forwarding Address Zip
Forwarding Address County Optional Forwarding Address County
Forwarding Address Country Optional Forwarding Address Country
Notes Optional Notes for the Contact. Field not available on the Bill and Boost plans.
Additional Notes Optional This column can be used to map additional (one or more) input columns to the `Notes` field. All data mapped to this column will be combined into a single Notes field in Smokeball (separated by a new line).
EIN Optional Employer Identification Number (applicable only to company type contacts). Field not available on the Bill and Boost plans.
Registered Date Optional The registered date for the contact (applicable only to company type contacts). Field not available on the Bill and Boost plans.
Registered State Optional The registered state (applicable only to company type contacts). Field not available on the Bill and Boost plans.
Registered State ID Optional The registered state ID (applicable only to company type contacts). Field not available on the Bill and Boost plans.
Registered Country Optional The registered country, if not US (applicable only to company type contacts). Field not available on the Bill and Boost plans.
Other Names Optional Other names for the Contact. Field not available on the Bill and Boost plans.
Marital Status Optional The marital status of the contact. Field not available on the Bill and Boost plans.
SSN Optional Social Security Number. Cannot be populated for the same contact in conjunction with ITIN. Field not available on the Bill and Boost plans.
ITIN Optional Individual Taxpayer Identification Number. Cannot be populated for the same contact in conjunction with SSN. Field not available on the Bill and Boost plans.
Alien Number Optional Alien Number. Field not available on the Bill and Boost plans.
Registration Number Optional Registration Number (applicable only to person type contacts). Field not available on the Bill and Boost plans.
Registration Authority Optional Registration Authority (applicable only to person type contacts). Field not available on the Bill and Boost plans.
Driver's License Number Optional Driver's License Number. Field not available on the Bill and Boost plans.
Driver's License State Optional Driver's License State. Field not available on the Bill and Boost plans.
Medicare Number Optional Medicare Number. Field not available on the Bill and Boost plans.
Country Of Citizenship Optional Country Of Citizenship. Field not available on the Bill and Boost plans.
Nationality Optional Nationality. Field not available on the Bill and Boost plans.
Passport Number Optional Passport Number. Field not available on the Bill and Boost plans.
Passport Issue Date Optional Passport Issue Date (MM/DD/YYYY). Field not available on the Bill and Boost plans.
Passport Country Of Issue Optional Passport Country Of Issue. Field not available on the Bill and Boost plans.
Passport Expiry Date Optional Passport Expiry Date (MM/DD/YYYY). Field not available on the Bill and Boost plans.
Tags Optional Tags for the Contact. Accepts multiple (; separated).
Not available on Bill or Boost
LEDES Client ID Optional
The UTBMS LEDES Client ID for the Contact.
This Client ID will carry over to any Matter involving the Contact.
Unique Company ID Optional This field is only relevant to Person Contacts and can be used instead of "Company Name" when there are multiple Companies in the import file with the same name, and you need to link one of them to a Person.
Matters
Matter ID Required Unique identifier used for Matter. This ID will not be visible in Smokeball and is an internal identifier only.
Matter Number / Reference Optional
Matter Description Optional
Matter Status Required
Branch Name Optional The Branch Office that the Matter relates to. Branch locations can be configured in the firm settings of your Account. Configured branches will then be available for selection.
Date Opened  Required MM/DD/YYYY
Date Closed Required if matter status = "Closed" MM/DD/YYYY
Matter Type Required
Matter type information should be included in this file, and you will then have the opportunity to map them to Smokeball Matter Types after uploading your Matters file.
When mapping your matter types to Smokeball matter types, some Smokeball Matter Types have multiple "acting for" options, for example, Insurance Coverage - Insured and Insurance Coverage - Insurer. Where this is the case, you will see various options available for selection in the Smokeball Matter Type dropdowns and can select the most suitable choice. Select who you represent the majority of the time.
Matter Type can be used to assist in choosing the correct matter type.
Billing Type Optional  Picklist of supported Smokeball Billing Types.
Attorney Responsible Name or Email Optional  Email address, name, or initials for the staff member to use as the Attorney Responsible on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Primary Person Assisting Name or Email Optional Email address, name, or initials for the staff member to use as the Primary Person Assisting on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Other Person(s) Assisting Name or Email Optional Email address, name, or initials for the staff member(s) to use as the Other Person(s) Assisting on the Matter (accepts multiple, & separated). If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Primary Originating Attorney Name or Email Optional Email address, name, or initials for the staff member to use as the Primary Originating Attorney on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Other Originating Attorney(s) Name or Email Optional Email address, name, or initials for the staff member(s) to use as the Other Originating Attorney(s) on the Matter (accepts multiple, & separated). If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Client ID or Email
Required
Can take multiple (separate entries with "&")
Contact ID or Email of the Client for the Matter. Must exist in Smokeball, or the contact import file for the current import.
Other Side ID or Email
Optional
Contact ID or Email of the Other Side for the Matter. Must exist in Smokeball, or the contact import file for the current import.
Other Sides Attorney ID or Email Optional Contact ID or Email of the Other Sides Attorney for the Matter. Must exist in Smokeball, or the contact import file for the current import.
Debtor ID or Email Optional Contact ID or Email Address of the Contact to use as the default Debtor (accepts a maximum of three, & separated). A Contact with this ID or Email must exist in Smokeball, or the Contact import file for the current import. Populate if you wish to set the default debtor for future invoices to a contact other than the Client of the Matter.
Tags Optional
Tags for the Matter. Accepts multiple (; separated). Tag colours will be applied at random during import, but can be edited later in Smokeball.
Archived Optional
Indicate if the Matter is Archived (Yes/No). If set to 'Yes', archive and destroy dates are required. To be archived, the status of the Matter must be Closed or Cancelled.
Archive/Box Number Optional
The archive or box number
Archive Location Optional
The archive location
Archive Comment Optional
Comments relating to the archive
Archived Date Optional
The archive date (MM/DD/YYYY). Required if the Matter is marked as archived.
Destroy Date Optional
The destroy date (MM/DD/YYYY). Required if the Matter is marked as archived.
LEDES Firm ID Optional
The LEDES Firm ID for the Matter.
The number assigned to your firm by your client for uploading your eBilling invoices. This typically, but not always, will be your firm's Employment Identification Number.
LEDES Matter ID Optional
The LEDES Matter ID for the Matter.
This is how your firm identifies the matter.
LEDES Client Matter ID Optional
The LEDES Client Matter ID for the Matter.
This is how your client identifies the matter. Most commonly, the Client Matter ID will be the claim number.
LEDES Timekeeper classifications Optional Select the UTBMS classification setting for Matter (If left empty, and other LEDES data is imported, this will default to the current Firm Settings option for Timekeeper Classifications).
Deleted? Optional Defaults to "No" unless supplied otherwise.
Matter Tags
Matter ID or Number
Required The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import.
Tags Required
Note: Tag colours will be applied at random during import, but can be edited later in Smokeball.
Matter Roles
Matter ID or Number
Contact ID or Email
Required Contact ID or Email of the Contact to use for the role. Must exist in Smokeball, or the contact import file for the current import.
Role Name
Required
The name of the role (e.g. 'Child', 'Judge', etc.). Depending on the Smokeball Matter Type chosen for each Matter, predefined supported roles will be available for selection; however, custom role names are also supported.
Matter ID or Number
Date Field Required
The name of the critical date field.
If the supplied field is not supported, a suggested list of supported critical dates will be provided based on the matter type for each matter.
Supported fields can be browsed in the following report: Supported Date Fields Report
Date Value
Required
The date for the corresponding critical date field (MM/DD/YYYY).
Matter ID or Number
Archived Required Indicate if the Matter is Archived (Yes/No). If set to 'Yes', archive and destroy dates are required. To be archived, the status of the Matter must be Closed or Canceled.
Archive/Box Number Optional The archive or box number
Archive Location Optional The archive location
Archive Comment Optional Comments relating to the archive
Archived Date Optional The archive date (MM/DD/YYYY). Required if the Matter is marked as archived.
Destroy Date Optional The destroy date (MM/DD/YYYY). Required if the Matter is marked as archived.
Account Balances
Matter ID or Number Required The ID or Number of the Matter associated with the Opening balances. Must exist in Smokeball, or the matter import file for the current import.
Opening Operating Retainer Balance ($) Optional The Opening Operating Retainer  Balance of the Matter ($) - e.g. "1500.50" or "800.00" or "0.00" or "123.00"
Opening Operating Retainer Balance Date Required if balance is above zero The date used for the Matter opening Operating Retainer balance (MM/DD/YYYY).
Opening Credit Balance ($) Optional The Opening Credit Balance of the Matter ($) - e.g. "1500.50" or "800.00" or "0.00" or "123.00"
Opening Credit Balance Date Required if balance is above zero The date used for the Matter opening Credit balance (MM/DD/YYYY).
Opening Trust Balance ($) Optional The Opening Trust Balance of the Matter ($) - e.g. "1500.50" or "800.00" or "0.00" or "123.00"
Opening Trust Balance Date Required if balance is above zero The date used for the Matter opening Trust balance (MM/DD/YYYY).
Activity Codes
Code Required A code used for the Activity (between 2-5 characters). Must be unique.
Type Required The type of activity (Fixed Fee, Time Based, Expense).
Description Required A short description of the Activity.
Rate ($) Required The rate ($) of the Activity - e.g. "100.50" or "500.00" or "0.00"
Duration (Hours) Required if Type = Time Based If type = "Time Based", the duration of the Activity in hours - e.g. "1.0" or "1.5" or "2.0" (if not set, will default to 1.0 in Smokeball).
Quantity Required if Type = Expense If Type = "Expense", the quantity of the Activity - e.g. "1.0" or "1.5" or "2.0" (if not set, will default to 1.0 in Smokeball).
Cost Type Optional If type = "Expense", indicate if the cost type is Hard or Soft (defaults to "Hard" in Smokeball if left empty).
Unbilled Time & Fees
Matter ID or Number Required The ID or Number of the Matter associated to the entry. Must exist in Smokeball, or the matter import file for the current import.
Staff Name or Email Required Email address, name, or initials of the staff member associated with the entry. The staff member must already exist in the account or be included in the Staff import file being imported.
Date Required The date of the entry (MM/DD/YYYY)
Type Required The type of entry (Fixed Fee or Time Based).
Activity Code Optional
Optional. Must match a Code from an Activity Type in Smokeball, or the Activity Type import file for the current import.
Assigning an activity code to an entry will not override/set other entry details (description, rate, duration etc).
UTBMS Activity Code Optional Optional. Cannot be combined with Activity Code (if UTBMS is used, Activity Code must be empty and vice versa). UTBMS Activity Code cannot be specified without a UTBMS Task Code. UTBMS Task Code can be specified without a UTBMS Activity Code.
UTBMS Task Code Optional Optional. Cannot be combined with Activity Code (if UTBMS is used, Activity Code must be empty and vice versa). UTBMS Activity Code cannot be specified without a UTBMS Task Code. UTBMS Task Code can be specified without a UTBMS Activity Code.
Subject Required A short Subject description of the entry.
Description Optional Description for the entry
Rate ($) Required The rate ($) of the entry - e.g. "100.50" or "500.00" or "0.00" (defaults to 0.00 if left empty).
Duration (Hours) Required if Type = Time Based If type = "Time Based", the duration of the entry in hours (allows 5 decimal places for precision). Must be equal to or above 0.01.
Billable Required
Yes/No.
Indicate if the entry is billable (defaults to "Yes" if left empty).
Write Off Required
Yes/No.
Indicate if the entry is written-off (defaults to "No" if left empty).
Unbilled Expenses
Assigning an activity code to an entry will not override/set other entry details (description, rate, quantity etc).
UTBMS Activity Code Optional Optional. Cannot be combined with Activity Code (if UTBMS is used, Activity Code must be empty and vice versa). Only one UTBMS Code can have a value (UTBMS Activity Code or UTBMS Task Code or all empty).
UTBMS Task Code Optional Optional. Cannot be combined with Activity Code (if UTBMS is used, Activity Code must be empty and vice versa). Only one UTBMS Code can have a value (UTBMS Activity Code or UTBMS Task Code or all empty).
Subject Required A short subject description of the entry.
Quantity Required The quantity of the entry - e.g. "0.5" or "1.5" or "2.0"
Billable Required Yes/No. Indicate if the entry is billable (defaults to "Yes" if left empty).
Write Off Required Yes/No. Indicate if the entry is written-off (defaults to "No" if left empty).
Invoices Basic
Invoice Number Required Must a be unique number with no leading zeros.
Debtor ID or Email Required
The ID or Email of the Contact who is the debtor on the Invoice (accepts multiple, & separated). Three maximum.
Matter ID or Number Required The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import
Issue Date Required
The Invoice Issue Date (MM/DD/YYYY).
Will also be used as the date for Fee/Expense line items.
Due Date Required The Invoice Due Date (MM/DD/YYYY).
Title Required Title text for the Invoice. 255-character max.
Subtitle Optional Subtitle text for the Invoice. This will appear under the main Title. 255-character max.
Notes Optional Footer notes for the invoice. This text will appear at the bottom of the invoice.
Total ($) Required
Overall Invoice Total (must match the combined amount of "Fee Total ($)" and "Expense Total ($)").
Must be above 0.00 - e.g. "1500.50" or "800.00" or "123.00".
Fee Total ($) Required
Must contain a value (even if 0.00).
Must be above 0.00 if "Expense Total ($)" = 0.00
Fee portion amount - e.g. "1500.50" or "800.00" or "0.00" or "123.00".
Expense Total ($) Required
Must be above 0.00 if "Fee Total ($)" = 0.00
Expense portion amount - e.g. "1500.50" or "800.00" or "0.00" or "123.00".
Amount Due ($) Required Where Amount Due is less than the Total amount, a payment will be created and applied to the invoice automatically on import for the difference.
Payment Date Required when the Amount Due is less than the Total Amount
Required when the Amount Due is less than the Total Amount (MM/DD/YYYY).
A payment will be created and applied to the invoice automatically on import for the difference.
Required.
Each invoice must have an assigned owner — the staff member who created or finalized the invoice. Enter the email address, name, or initials of the staff member. The staff member must already exist in the account or be included in the Staff import file being imported.
This will also be the staff member used for assignment of the Fee and Expense line items on the invoice.
Invoices Detailed
Matter ID or Number Required The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import.
Issue Date Required The Invoice Issue Date (MM/DD/YYYY).
Fee Discount ($) Optional
Discounting is an invoice-wide action. You can apply a flat-dollar discount to the time and fees portion of the invoice.
Note: You cannot apply a discount to the expense portion of an invoice.
Surcharge ($) Optional You can apply a surcharge by a flat amount on the invoice.
Surcharge Description Optional
Provide a custom surcharge description that will appear on the invoice (max 32 characters).
Note: If left empty or not mapped, this will default to "Surcharge".
Total ($) Required Overall Invoice Total. e.g. "1500.50" or "800.00" or "123.00".
Required when the Amount Due is less than the Total Amount.
Required.
Invoice Number Required The Invoice number associated with the item. An invoice with this number must exist in the Invoice import file for the current import.
Staff Name or Email Required Email address, name, or initials of the staff member associated with the item. The staff member must already exist in the account or be included in the Staff import file being imported.
Date Required The date of the item (MM/DD/YYYY)
Type Required The type of the item (Fixed Fee, Time Based, Expense).
Subject Required A short Subject description of the item.
Description Optional If type = "Time Based", the duration in hours (allows 5 decimal places for precision). Must be equal to or above 0.01.
Rate ($) Required The rate ($) for the item - e.g. "100.50" or "500.00" or "0.00".
Duration (Hours) Required if type = Time Based If type = "Time Based", the duration in hours (allows 5 decimal places for precision). Must be equal to or above 0.01.
Quantity Required if type = Expense If type = "Expense", the quantity - e.g. "1.00" or "1.50" or "2.25" (must be equal to or above 1.00)
Write Off Required Indicate if the item is written-off (defaults to "No" if left empty).
Cost Type Optional
If type = "Disbursement", indicate if the cost type is Hard or Soft (defaults to "Hard" in Smokeball if left empty).
Hard costs are costs paid directly to the supplier, e.g. search fees. Soft costs are costs that your firm can choose to pass to the client, e.g. costs of printer paper and ink.
Memos
Memo ID Required Unique ID for the Memo. This ID will not be visible in Smokeball and is an internal identifier only.
Matter ID or Number Required Required for all Memos. The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import.
Date & Time Required
Memo date & time (24-hour). Not visible in Smokeball Web but retained for historical reference. If not populated, will default to the date of upload (MM/DD/YYYY HH:MM).
E.g. 05/08/2024 14:30
Subject Required
Subject of the Memo (If not populated, where possible, the first 50 characters of the memo text will be used).
Maximum 200 characters.
Text Required Full Memo text (If not populated, where possible, the subject of the memo will be used).
Created By Staff Name or Email Required Email address, name, or initials of the staff member who created the Memo. The staff member must already exist in the account or be included in the Staff import file being imported.
Tasks
Task ID Required Unique identifier for the Task. This ID will not be visible in Smokeball and is an internal identifier only.
Matter ID or Number Optional The Matter ID or Number of the associated Matter (optional). If supplied, must exist in Smokeball, or the contact import file for the current import.
Name Required Name of the Task
Description Optional Task description (max 8,000 characters)
Status Required Task Status (Complete or Incomplete)
Created Date Required Date the Task was created (MM/DD/YYYY)
Created By Staff Name or Email Required Email address, name, or initials of the staff member who created the Task. The staff member must already exist in the account or be included in the Staff import file being imported.
Assignee Staff Name or Email Optional Email address, name, or initials of the staff member to use as the Task assignee (accepts multiple, & separated). If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Due Date Optional Due date of the Task (MM/DD/YYYY)
Completed Date Required if status is "Complete" The completion date of the Task. Required if Status = Complete (MM/DD/YYYY)
Completed By Staff Name or Email Required if status is "Complete" Email address, name, or initials of the staff member who completed the Task. Required if Status = Complete. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Duration Optional Duration of the Task (MM or HH:MM) - e.g. "01" or "15" or "1:30" or "01:06".
Calendar Events
Event ID Required Unique identifier for the Event. This ID will not be visible in Smokeball and is an internal identifier only.
Matter ID or Number Optional The Matter ID or Number of the associated Matter (optional). If supplied, must exist in Smokeball, or the matter import file for the current import.
Subject Required Name of the Event (255 character maximum).
Location Optional The Event location (255 character maximum).
Comments Optional Additional comments or description for the Event.
Created By Staff Name or Email Required Email address, name, or initials of the staff member who created the Event. The staff member must already exist in the account or be included in the Staff import file being imported.
Attendee Staff Names or Emails Required or Group Calendar Name
Accepts multiple & separated.
Each Event must have at least one Staff Member or Group Calendar as the Assignee (or both).
For Staff, enter the email address, name, or initials of the staff member. The staff member must already exist in the account or be included in the Staff import file being imported.
Note: An attendee’s Calendar Event will only be visible in the application once imported if they are an active paying user or a former Staff member.
Group Calendar Name Required or Attendee Staff Emails
Accepts multiple, & separated.
Each Event must include at least one Group Calendar or Staff attendee (or both).
All Day Event Required Indicate if the Event is all day (Yes/No).
Start Date & Time Required The start date and time (24-hour) of the Event (MM/DD/YYY HH:MM).
Note: Smokeball does not allow bulk imports of events more than two years old.
End Date & Time Required The end date and time (24-hour) of the Event (MM/DD/YYY HH:MM).
Must be equal to or greater than Start Date Time.
Time Zone Optional
Optional: Time zone for the Event in IANA format (e.g. 'America/Chicago').
By default, the firm address set in the Smokeball settings will be used to determine the time zone for the event. This can be overridden if needed by providing a value in this column.
Billable Required
Indicate if the Event is Billable (Yes/No).
All day Events or Events longer than 12 hours cannot be marked as Billable.
4 out of 5 found this helpful
