Querious Integration
Plan_BoostGrowProsper.svg
Learn how to integrate Smokeball with Querious, an AI-powered Legal Conversational Intelligence™ platform to assist with legal admin tasks.
6789f3f8bafc481a65a07541_logo.svg
Learn more about Querious on their website.
Connecting Querious to Smokeball
To connect your Querious account to Smokeball:
  1. Log in to Querious and navigate to the Integrations page.
  2. From the Practice Management Integrations section, select Connect next to Smokeball.
  3. Log in with your Smokeball login credentials.
Once you have successfully connected to Querious, Smokeball should appear on the top action bar of your Querious account.
How the Querious Integration works with Smokeball
Meetings tracked in Querious can be synced to Smokeball as time entries for relevant matters. To sync a time entry:
  1. Hover over Smokeball on the top action bar in Querious, then click on Billing Entries.
  2. Select an entry on the list. Start typing the matter name and select it from the drop-down menu.
  3. Make edits to the Description if needed, and if the entry is billable, review the Duration field and update it as needed.
  4. Select Submit Entry.
  5. Navigate to the matter in Smokeball and select the Time & Fees tab. The Querious entry should appear in the list of time and fee entries for that matter.
Getting support for the Querious Integration
If you need assistance with using Querious or have further questions on how it integrates with Smokeball, get in touch with the Querious support team on their website.
