Smokeball Character Limits
Many fields throughout Smokeball have a maximum number of characters they will accept. This article lists the current character limits for common fields so you know how much text you can enter in each.
Note
Limits marked with a tilde (~) are approximate. If you paste text that exceeds a field's limit, the extra characters will be trimmed or the entry may not save.
Messages, Memos & Notes
FieldCharacter limit
Memos, and the Summary text box in Invoices10,000
Communicate messages and Phone message notes~2,000
SMS messages320
Billing Entries
Billing Entry Subject Line1,000
Billing Entry Description Line1,000
Documents
Document names255 (Windows limitation); at least 480 for documents renamed within Smokeball
The 255-character limit on document names (including the names of their folders and sub-folders) is a Windows operating system restriction rather than a Smokeball one. Documents renamed within Smokeball can use longer names (at least 480 characters).
Tasks
Task name300
Task details8,000
Task notes3,000
Workflows
Workflow Task name487
Workflow sub-tasks445
Other subject/name fields in the UI (workflow tasks, etc.)300
14 out of 16 found this helpful
