Sync Smokeball with your Outlook calendar
Learn how to connect and sync your Outlook calendar with Smokeball, allowing you to manage calendar events either in Outlook or Smokeball, depending on your firm's preferences.
Any calendar event created in Smokeball will appear on Outlook, and every event created in Outlook can appear in Smokeball (unless it's marked private in Outlook).
  • Important Note: If a Calendar event is created in Outlook and marked as private, it will not push over to Smokeball. Make sure you place a Block in your Smokeball calendar as needed.
You can configure both features in the Outlook and Notifications tab located in Smokeball Settings.
How to access Outlook and notification settings
  1. Select File from the top-left corner of the Smokeball desktop app.
  2. Select Smokeball Settings.
  3. Navigate to the Outlook and Notifications tab.
Sync your Smokeball calendar with Microsoft 365
Follow these steps if your firm uses Microsoft 365:
  1. Select the Outlook and Notifications tab and then navigate to the Calendar Sync section.
  2. Enter the email address with the calendar you want to sync in the text box.
  3. Select the Set Up button.
  4. You'll be directed to sign in with your credentials.
  5. Once you have authorized your account, select the calendar you wish to sync and select Next.
    • The Disable option allows you to disable the sync of your current calendar without de-authorizing the integration.
  6. Select Save. The status bar will turn yellow and indicate the sync is in progress.
After completing the process, the status bar will change to green. Any changes made in your Smokeball or Outlook calendar will now automatically sync with the other.
Important Note: You can only sync 1 Smokeball user to 1 unique Microsoft 365 account.
  • For example, User A can sync their Smokeball calendar to any calendar in their own Microsoft 365 account.
  • However, User A and User B cannot sync both of their Smokeball calendars to the same Microsoft 365 calendar or account.
Sync your Smokeball calendar with your local Outlook desktop calendar
  1. In the Outlook and Notifications tab, navigate to the Calendar sync section.
  2. Select Setup calendar sync manually.
  3. Select Outlook Desktop - Local Sync and then select a calendar.
Frequently Asked Questions about Microsoft 365 Calendar Sync
Can I connect my GoDaddy hosted Outlook account to Smokeball?
Yes, the Microsoft 365 Calendar Sync with Smokeball works for Microsoft 365 accounts hosted on GoDaddy.
If I switch from Local to Cloud sync, will my events duplicate?
No, events should not be duplicated.
Will choosing Cloud sync affect the Outlook email integration with Smokeball?
Syncing the calendar should not affect how emails are saved to matters, whether manually or automatically, through threads.
Do I have to use the set up wizard?
No. You can still sync calendars manually by selecting Setup calendar sync manually (pre-sync) or Use manual setup (post-sync).
Can I de-sync?
Yes. Select the disable button under the status bar.
I get a "Need admin approval" message from Microsoft after signing in. How do I fix this?
This message can appear if your firm's Microsoft 365 organisation has security rules to block individual users to consent to third party integrations.
To resolve this, your organisation's Microsoft 365 Administrator needs to grant admin consent to the Smokeball App by following the steps below:
  1. Go to Azure Portal: https://portal.azure.com
  2. Search for “Enterprise Applications” and open it.
  3. Find the app: Look for Smokeball in the list.
  4. Open the app and go to Permissions under Security in the left-hand side.
  5. Click Grant admin consent for [Your Organization].
  6. Confirm the permissions and approve.
Alternatively, they can use the Admin Consent Workflow to set up a process around requesting access for third party applications.
Choosing the best sync option for your firm
  • If your firm uses Microsoft 365 accounts, we highly recommend using Cloud Sync. You will be able to get updates to calendar events in real time from any device that can access Outlook 365, such as the Outlook mobile app. Since all data is saved to the cloud, there’s less likelihood of data corruption and interference that could cause issues with syncing.
  • For any other type of mailbox, such as IMAP or Gmail, use Local Sync to connect your calendars. Note that with this option, you can only sync your calendar on one device at a time.
23 out of 51 found this helpful
