Default Document Folders
Matter Configuration helps you create matter-specific default document folders that will automatically appear in the files area in any matter.
How to Create a Default Document Folders
  • On the "Default Document Folders" tab, click "add a folder." You can add as many folders as you would like.
  • Select "Create" to add the folder.
  • You can create sub-folders by creating the folder and dragging under the appropriate folder.
  • You can also right click to add a sub-folder
  • You can create matter-specific folders by right-clicking the source folder and clicking Add folder
2 out of 2 found this helpful
