- Make sure a scanner is connected to your computer.
- Note: Consult the documentation which came with your specific scanner model for setup instructions.
- Learn how to install a scanner in Windows.
- Open your matter and then select the Scan button.
- Select the scanner you wish to use in the pop-up window.
- Select the source of the scan (if applicable to your scanner) and then select OK.
- Once the scan is finished, complete the prompt asking you to name the file. You can also convert the file into a PDF.
Note: If you utilize a network scanner where documents are scanned to a shared drive, use the Importing Documents and Folders button to add the scanned document from the shared drive to your matter.
You can drag and drop files from a folder or your desktop into the Documents & Emails section in a matter.
You can also use Smokeball’s integration with Ricoh ScanSnap to scan documents.
