Insert a Field
- Click on the desired location in the document.
- Double click the appropriate field from the Smokeball toolbar.
- In the example below, you will see the field appear as "<<Client/Full Name(s) (All Parties)>>” if you select Show fields in the Smokeball Toolbar. Selecting Show values will display the full name of the client as entered into matter details.
- Learn more about Field Insertions.
Insert an Ask
- Create the Ask.
- Click on the location of the document where you want to insert the Ask and then double-click the Ask from the Smokeball toolbar to insert it.
- Select Show values at any time to test your document in real time and see information inserted.
- If you want to test your Asks, select Run questions for this form.
Once any Field (or Ask) has been inserted, you can change the format:
- Click on the field (do not select the field).
- Select the format from the options provided in the Smokeball toolbar.
- Select the Apply format button.
- Remember to Save & Close your template. The template will be ready to use in the Forms & Templates Library.
- You can automate some templates faster using Document Containers.
- Smokeball will automate publicly available Court and Authority forms. Submit additional forms (in batches of 10) with a website URL to your Account Manager, and our team will add them to the library.
