Smarter Drafter Integration
Smarter Drafter is an automated legal document provider based in Australia. Smarter Drafter connects with Smokeball and allows you to:
  • Use Smokeball contacts when creating forms in Smarter Drafter
  • Save documents generated in Smarter Drafter to a matter in Smokeball
Smarter-Drafter-Normal-120px.svg
To get started with Smarter Drafter, visit their website to schedule a consultation.
A note on support scope
Smokeball integrates with this third-party solution but does not develop or manage it. Our support team can assist with issues related to the integration not functioning correctly within Smokeball (e.g., it's not appearing or working as expected). Questions about the tool's functionality, features, or capabilities should be directed to Smarter Drafter (https://smarterdrafter.com.au/).
Setting up the integration
  1. Log in to Smarter Drafter, then navigate to Account Settings.
  2. Select Integrations, then select Smokeball - Legal Practice Management Software.
  3. Click Enable. You will be prompted to enter your Smokeball login details.
From here, the integration will be activated. All contact and matters will be synced from Smokeball to Smarter Drafter.
How the integration works
Syncing contacts
Contacts in Smokeball are synced to Smarter Drafter every time you use a Smart Q&A Form. To use a Smokeball contact, start typing their name into the Name field and select it to automatically fill in their details in the document.
The following fields will be automatically populated in the Smart Q&A form:
  • Name
  • Address
  • Trust information
  • Other personal details
After submitting a document, you will be asked if you want to save any new contact information into Smokeball.
Sending documents to Smokeball
After submitting a document in Smarter Drafter, you will be asked if you wish to send the document to the Smokeball matter. From there, you can choose the matter to send it to and the document will then appear in a folder within the Smokeball matter.
You can also send the document to Smokeball at any time by selecting Send to Smokeball from the Submission table.
1 out of 2 found this helpful
