With the InfoTrack integration, you can add process serving to any filing or order it as a stand-alone. Once a Process Serve order is complete, all served documents and related disbursements are logged in Smokeball.
Access Process Serving
Open a matter file and select Process Serving from the matter tab:
You can also access Process Serving by right-clicking on a document, to add the document to the service of process.
If you have CourtSync enabled, Process Serving will be available under the Litigation Services menu.
How Process Serving works
Clicking on Process Serving will open InfoTrack in a browser window, where you can view all your current Process Serves and create new ones.
Note: Process serving is only available on Litigation matter types in Smokeball; the Process Serving button will not appear on any other matter types.
When you select the Process Serving button, the Matter ID, State, Initiating Parties, Responding Parties and Lawyers information will be sent to InfoTrack.
If information is not syncing properly between Smokeball and InfoTrack, get in touch with InfoTrack support for further investigation by lodging a request on their website or emailing helpdesk@infotrack.com.au.Â
